overclocked kernel is here
    Originally posted by vkk View Post
    Tried with neorom recovery and it worked. thnaks
    only use RKAndroidTool flash recovery and the stick back??
      Flashed the whole rom again, just selected the other recovery before flash
        vkk Thankyou for the important feedback. I have edited my post to add a link to a different recovery.img. although the one included did work for me, it must depend on the TV used. I just wanted to keep the rom as original as possable
          I've tested the 4.2.2 Finless ported rom, and I still can't get antutu to finish the benchmark if I use the 720p extreme oveclocked kernel with the gpu fix, it will force close once it stars testing the gpu...
            changing the rom will not make any difference your gpu cannot handle the frequency, although the rom is faster
              how about a 1800Mhz CPU 1333Mhz Ram and 800Mhz Gpu +0.125mv voltage boost for the cpu/gpu/ram
              you need more voltage to keep it stable
              more discussion here
              current devices(rockchip sucks)
              Hardkernel ODROID C1 running android kitkat
              Hardkernel ODROID XU3-L Running Linux/openelec (primary media server)
              rPi model B+ running nothing ... bricked
                Sam it definitely faster than the neorom.
                Some people might need higher voltage kernels, the gpu performance didnt increase for me with the 800mhz kernels.
                  Probably won't show in benchmarks but it should help with 1080P
                    I get 3d-3500, while sam shows 3d-4300.
                      use the governor ondemand to get the high score
                        agree the governor tables could use some tweaking
                          Sam321, would Antutu CPU Master allow users to tweak their clock speeds / voltages or are these hard coded in your kernel?
                            Re: overclocked kernel is here
                            Clock spped yes, voltage no.
                            leolas
                            My devices:
                            Gearbest.com)
                              I use MX Player with the MX Player Codec (ARMv7 NEON) and it works fine...
                              OK it works for me too, only with the "H/W+" mode on
                              a funny thing with this mode, now i have the inverted "mouse effect", if i move it = laggy ( big bunny h.264 1080 )
                              A message to those who can't run an antutu test with the overclocked kernel
                              i just tried the PSU send with my stick ( KY AC/DC ADARTOR " " KY-3012 ... 5V 2.0A ) ... and i confirmed the bad feeling i had about it, i get a reboot with it
                              the PSU that i use is a BELKIN F8Z783cw ( made for Ipad : 2.1A ) and it works
                                leolas
                                Sorry, I was referring to the 'pro' edition.
                                Antutu CPU Master Pro
