leolas
overclocked kernel is here
Please can someone send me a link with evident frame skiping problem? Using an oc 1080p at 1800 cpu and 1440 ram kernel I cant notice it.
Originally posted by sam321 View Postvideo test fix for the old MK802-IV or UG007B http://www.cloudstor.es/file/m1_NDU5MQ/ no overclock
i would love to see a 1080p kernal with a fix for the frame skipping
BaDTaG
First of all, HI to the community!
For the last hour or two I em trying to boot up MK802-IV with sam321's test fix kernel. Sadly i have no luck. My device wont boot up and it get stuck-freezed on splash screen.
Have tried bunch of sams321's OC kernels and all worked just fine - this wont =/ Maybe i em doing something wrong considering MK802-IV as my 1st mini PC.
Would love to report my results in if i could make it work.
Frame skipping fix kernel
720p no overclock http://www.cloudstor.es/file/m1_NDYwMg/
1080p no overclock http://www.cloudstor.es/file/m1_NDYwMw/
thanks a lot to phjanderson for the fix.
going to update the overclocking options and this fix included. I am just waiting for more feed back as it takes quite a bit of effort and I just want to get it right the first time
The "killa sample" runs fine now, totaly SMOOTH ! ( MXplayer lags on some other 1080p mkv that i've tried, but these videos play correctly on other video player : MXplayer sucks )
Thanks a lot
I'm ready for the overclocked versions of it !!!
PS: didn't test the bluetooth but wifi works
PS²:when i turn off the stick with the menu bar ... it boots up a few second later ? not sure it commes from this kernel but i've just noticed it now (i'm using the NEOTV rom )Last edited by fabienk; 30 July 2013, 11:00.
I have updated all the kernel options with the video fix and created a new thread in the Kernel Development section, come and have a look http://www.freaktab.com/showthread.p...h-RTL8188-WiFi
Originally posted by sam321 View Postwe are still refining the video fix, I find the 720p to give the best video performance, of course if you use a 1080p kernel the system has to render thousands more pixels which does slow down the stick. People that are interested why not come over and help out testing
http://www.freaktab.com/showthread.p...1850#post81850
Edit: ignore this I have found your fixed kernel for the Cozyswan S400. Might be worth updating the first post Sam321 to remove the Cozyswan part?Last edited by emptybee; 01 August 2013, 17:04.
There are currently 3398 users online. 0 members and 3398 guests.
