TX5 Pro Official Stock Firmwares, updates and discussion
Originally posted by tinuz97 View PostThis link in the first post is dead :/ With 9377 WiFi chip - http://www.mediafire.com/file/1p9515...7-20161121.img
Hi. I'm new here and to android boxes in general.
For some reason I can't install any OTA updates on my box (Tx5 Pro 9377).
I tried two different 2017 version updates and it errors out on install.
I tried 2 different sd cards, formatted with just the files in them and nothing.
I get something like:
E: could not mount /dev/block/mmcblk0 (sd card read-only)
The sd cards aren't write protected.. I even tried using a usb.
I'm back on TX5pro-9377-20161121.img
Img files work fine but no dice with OTA zips.
I've tried through the update/backup app and the recovery menu.
What am I doing wrong? Any suggestions?Last edited by H215; 01 June 2017, 00:00.
Originally posted by earchant View Post
Heated the whole board for about a minute to avoid the board bending from heat in one area (500degrees). Then I did a circular pattern going around the board for about 3 min focusing on the flash memory for about 15 seconds at a time.
Pretty sure the error is due to flash memory. You'll start smelling the solder knowing it's being reflowed. After its done let it cool completely before touching or moving it.
Pretty standard. Just remeber this is prob only temp fix and heat gun isn't technically a proper reflow machine.
Thanks for the instructions.
Originally posted by H215 View PostHi. I'm new here and to android boxes in general.
Full flash using USB Burning Tool
I originally used usb flash tool to update to TX5pro-9377-20161121.img
I can get into recovery and install full update and custom images from recovery as well, just not OTA zips.
Strange..
Is there a way to make zip updates into img updates?
They rarely work in my experience. When they do work it's generally a one off and
you will never get the next one to work.
These guy's selling the boxes are all knocking off each others Firmware.
The Amlogic USB Flash Tool is your safest surest way to clean Flash.
Originally posted by kostaman View Post
You can ask the Chinese Fiirmware Dev's why the OTA's don't Update?
I was gonna make a img update from the system.new.dat contents in the ota zip,
but the system.new.dat wouldn't extract from the zip. Error on that file during extract.
After searching around I found one that extracted with no errors.
So here goes a proper working TX5pro-9377-p212-ota-20170106.zip.
I updated fine with this.
edit:
There's also this with a newer date and a few more apps but has a gostreamer boot logo.
https://www.gostreamer.com/downloads...7_06032017.zip
I originally used the system.new.dat contents of this ota update to create a full image file.
It installed fine but was over 1gb and I didn't like the gostreamer boot logo..
Keep in mind that this was my first dabble at creating an img file so I might have copied junk files in it.
The original file above is about 800mb. It might install fine as-is but I haven't tested it.
My TX5 Pro is the tanix variant from geekbuying btw.Last edited by H215; 04 June 2017, 03:26.
Why do not ask TANIX directly for updates? They are at Twitter: https://twitter.com/Tanix_Box
As I have some friend in that company, I am going to ask them if possible to place all their firmwares in a website for download...
Hope can helpAndroid TV Box direct from China. English & Español
Originally posted by Javimetal View PostWhy do not ask TANIX directly for updates? They are at Twitter: https://twitter.com/Tanix_Box
Hope can help
http://www.tanix-box.com no coverage on the TX3 or TX5 units yet only the TX7/TX8 and TX2!
Tanix TX5 Pro Firmware 2GB/16GB 9377 20170306 Full Image
Available now: Tanix TV Box FirmwareAndroid TV Box direct from China. English & Español
There are currently 2822 users online. 1 members and 2821 guests.
