No, in this case you can NOT use the internal upgrade app. This is a complete firmware. The links to both versions are:
Uploaded on 20161216
Tanix Amlogic S905X with 6255 wifi chip PC Upgrade http://www.mediafire.com/file/1d8acc...5-20161123.img
Tanix Amlogic S905X with 9377 wifi chip PC Upgrade http://www.mediafire.com/file/1p9515...7-20161121.img
Please check the SN Code at the bottom of the device, 77 represents 9377, P5 represents 6255
If your SN code does NOT match one of thes both version, You might not use them at all. In this case you need to wait until you get an update.
For this you need to check this blog: http://blog.geekbuying.com/index.php...ware-20160809/
This is the link to the actual burning tool: http://www.mediafire.com/download/or...l_2.0.5.15.rar
Male 2male is really easy to find. You can find shorter and longer cable. Mine is about 6FT long.... just as an example:
