TX5 Pro Official Stock Firmwares, updates and discussion
Hi Guys
TX5Pro suddenly refuses to power on at all.
Stuck in standby with red light only.
Does anyone know what the log means? See Pastebin.
Tried every method including start usb burning tool then insert usb.
It is immediately recognised always stops at 7% with the same error.
Always red light. Never goes to Blue light.
No idea what the error means.
Originally posted by bovirus View Post@Rigattoni
Many thanks for very intersting info about WiFi chip and Firmware update
@bluesmanuk
Could you please update firmware with info about December 2016 firmware explain here
http://freaktab.com/forum/tv-player-...451#post619451
Please add this important info in first post
Please check the SN Code at the bottom of the device, 77 represents Wifi chipset 9377, P5 represents Wifi chipset 6255
Please use the right firmware foir specific Wifi chipset.
If your SN code does NOT match one of thes both version, You might not use them at all. In this case you need to wait until you get an update.
Please add in first post the link for
Amlogic USB Burning Tool - http://www.mediafire.com/download/or...l_2.0.5.15.rar
- Firmware TX5 Pro (board with 6255 chipset)
OTA
TX5 Pro (6255) - OTA 23.11.2016 - Download (OneDrive)
Full flash image
TX5 Pro (6255) - Full image firmware v. 23.11.2016 - Download (mediafire)
- Firmware TX5 Pro (board with 9377 chipset)
OTA
TX5 Pro (9377) - OTA 12.01.2017 - Download (OneDrive)
Full flash image
TX5 Pro (9377) - Firmware full image v. 21.11.2016 - Download (mediafire)
Originally posted by blyx21 View Post
You can try just make sure you have the original stock rom firmware . But why use tanix stock rom there are a lot of good custom rom out there?
I am not aware of any ROM that support TX95 and the 9377 WIFI, only the XTMod (by Xannytech) w/o that WIFI chip.
https://forum.xda-developers.com/and...1#post71283931
I was looking for a ROM that is:
1. fully compatible with TX95
2. is up-to-date with latest amlogic firmware
TX5 Pro seems to me compatible. Let me know if you know of any others.
I returned box to seller (China) after trying 2 images sent to me failed with same result.
Just received a response from seller that the box has Hardware Failure and it will be replaced.
Still having issues with the SD card getting corrupted - message in the notification bar. Is anyone having this issue? Seems like the next time I turn the box on after to having to format the SD card it happens again.
It's a 32Gb SanDisk memory card.
Would appreciate any help or if it's happening to others!
Also the ram management seems to be poor. Only a couple of apps open but still loads them afresh each time i go back to the app.
Is there a better firmware for the TX5 Pro - 6255 version?
Thanks!
Originally posted by m1tch3m View PostStill having issues with the SD card getting corrupted - message in the notification bar. Is anyone having this issue? Seems like the next time I turn the box on after to having to format the SD card it happens again.
Thanks!
http://freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s905x/others-aml-s905x/firmware-roms-tools-bx
You could try one from here.
Any suggestions for my box?
Thanks.
Thanks for your reply. I've had a browse through but not sure which is the best one to go for. Most seem to have some sort of issue whether it be the WiFi, standby, brightness or whether it's compatible with my box.
Thanks.
Hello , I am also a happy owner of the TX5 , for 10 days now .
I wanted to asked , if anyone has updated the Kodi 16.1 ( that comes pre-installed ) to Kodi 17 ?
On playstore I don't have the ''update'' option . Only the '' uninstall '' and the '' open '' .
Is it ok , if I use the option to uninstall first , and then install , through playstore ?
Thank you !
Originally posted by leftergr View PostHello , I am also a happy owner of the TX5 , for 10 days now .
Thank you !
However if you want to follow the official path then you simply uninstall the one on the box and then install from the official store source where you will then get updates.
Dependant upon your uses for Kodi though, you may find that 17 is not a generally recommended option.
There are currently 2911 users online. 1 members and 2910 guests.
