TX5 Pro Official Stock Firmwares, updates and discussion
    Was any member were able to get the Logitech Harmony Ultimate Home to work with the Tanix TX5 Pro.
      Originally posted by olympicwiz View Post
      I installed HBO GO on Tx5 Pro but can not get a sound at all. Has anyone come across this issue?
      audio is muted when you first start the app by default...stupid...click the screen and unmute.
        The SD Card on my box keeps getting corrupted (message in notification bar).
        I turn off my box properly from the power menu and not just switch off but it keeps happening.
        Is this happening with anyone else?
        I'm on the November firmware (2nd to latest firmware).
          After upgrade, wifi is poor.. can't connect to 2,4GHz with 40MHz bandpass; and can't connect to 5GHz wifi AC 80MHZ!! 2,4GHz is now limited to 20MHz and 5GHz limited to 40MHz ! And not resolved black bar in the bottom on the GooglePlay. New version, patch or solution to restore wifi for AP6255 ? thanks
            Just flash again...
              Hi folks,
              not found yet, but do we have a TWRP version for the TX5?
              I need to have xposed installed...
              please ignore my posting. I got xposed installed now.
                If I upgrade to the latest December firmware via pc (currently on November) will this wipe the device or just upgrade the OS and leave apps/settings etc unaffected?
                  The box will be wiped completely. It´s no Update, it´s a full system. You need to backup your data before flashing.
                  Upcoming updates will be OTA in case we will get some...
                    Damn, couldn't be bothered setting it up again, haha.
                    I hope the next update is an ota rather than a full system and wipe update.
                    Thanks for the info!
                      Was any member were able to get Netflix to work with the Tanix TX5 Pro?
                        Mine keep saying Please make sure that your device has network connectivity and the Date and Time setting are accurate. (-3)
                          Did you set the time zone correct?
                          Deactivate the automatic time, choose the correct time zone and then activate the automatic settings again.
                          I am able to start Netflix without issues.
                            Netflix works fine for me. If I remember, I deleted the bundled version and installed the latest from Google Play.
                              Thanks guys will try and report back.
                              Also installed Showtime Anytime and it worked fine but now refusing to work saying something about HDMI transmission
                              Sent from my MI MAX using Tapatalk
                                @Rigattoni
                                Many thanks for very intersting info about WiFi chip and Firmware update
                                @bluesmanuk
                                Could you please update firmware with info about December 2016 firmware explain here
                                http://freaktab.com/forum/tv-player-...451#post619451
                                Please add this important info in first post
                                Please check the SN Code at the bottom of the device, 77 represents Wifi chipset 9377, P5 represents Wifi chipset 6255
                                Please use the right firmware foir specific Wifi chipset.
                                If your SN code does NOT match one of thes both version, You might not use them at all. In this case you need to wait until you get an update.
                                Please add in first post the link for
                                Amlogic USB Burning Tool - http://www.mediafire.com/download/or...l_2.0.5.15.rar
                                - Firmware TX5 Pro (board with 6255 chipset)
                                OTA
                                TX5 Pro (6255) - OTA 23.11.2016 - Download (OneDrive)
                                Full flash image
                                TX5 Pro (6255) - Full image firmware v. 23.11.2016 - Download (mediafire)
                                - Firmware TX5 Pro (board with 9377 chipset)
                                OTA
                                TX5 Pro (9377) - OTA 12.01.2017 - Download (OneDrive)
                                Full flash image
                                TX5 Pro (9377) - Firmware full image v. 21.11.2016 - Download (mediafire)
