VORKE Z6 Android 7.1.2 Amlogic S912 TV BOX 3/32GB eMMC5.0 WIFI BT Gig LAN
Has anyone tested Wifi and ethernet speed on this? Says that it can only do 25 mbit on 5GHz and 125mbit on ethernet? I had a S10 box which I fried. I could do at least 100 mbit on 5GHz on it.
And does anyone have a new coupon for tanix? I'm only looking to run Libreelec. I also use Quasar a lot. Stream 4k movies. That is why I need 32 GB at least. Does it work to flash LibrELEC on this? I only want LIbreELEC
which is the newest rom for this box? Somebody use the Vorke Z6 already some time and can inform concerning the heating problem, principally using Kodi? Thanks a lot, i am thinking to buy some of this boxes.
I think it is the same as Tanix TX92, correctly? so can be used the same rom-software from Tanix for the vorke box, in the case if it would be necessary?
Originally posted by tombraga View Postwhich is the newest rom for this box? Somebody use the Vorke Z6 already some time and can inform concerning the heating problem, principally using Kodi? Thanks a lot, i am thinking to buy some of this boxes.
i'm waiting for 11.11 there will be a discount for this tv-box on geekbuying
Originally posted by JoseM View Post
http://blog.geekbuying.com/2017/10/v...date-20171011/
yes
But do you think it will be cheaper than 67 USD (57 Euros) on geekbuying which i have at this moment?
you want buy Tanix or Vorke?
the rom is from 06.09. perhaps when we get now the new box, will already has this new rom?
somebody got the vorke box the last few days? which rom-version you got?
thanks for the informations, yes me too, i am waiting also for 11.11, also want to buy one.
And no reason to order at 11.11 and risk receiving the item after the New Year.
Unleashed by ONEPLUS 3T rooted
Originally posted by fatbasket View PostApart from the price and the board sticker I can't see any difference in the hardware between the Tanix and the Z6, aside the firmware - logo maybe?? Be good to see if somebody had both if there are any true differences - both firmwares should run on both boxes??
There are currently 2120 users online. 2 members and 2118 guests.
