VORKE Z6 Android 7.1.2 Amlogic S912 TV BOX 3/32GB eMMC5.0 WIFI BT Gig LAN
    Originally posted by Deibi View Post
    I do everything just like you tell me, I've tried with the other pins, and nothing.
    it's frustrating.
    this is what I am doing, the controllers are active.
    Thank you very much for the help, I had to break it without wanting to.
    I hope you have brought your box back to live since, but if not try another combination.
    I just flashed another Vorke Z6 and couldn't get it to be detected by usb burning tool. ( this one i hadn't opened as it still booted so i used reset button ).In your case it would still be the eMMC pins
    At the end i got it connected by first connecting power adapter, then press reset button and insert usb cable.
    So try different combination, but after each failure disconnect completely.
    I think it's almost impossible to hard brick these devices, so keep trying.
      Originally posted by Jancales View Post
      So far I have connected 3 Vorke Z6 boxes ( I have 7 more LOL) and all 3 give me the below trouble at certain times.
      I have used different tv's and different hdmi cables.
      When I do a factory reset the symptom will not occur for the first 20 - 30 start ups. Then it will be back, but not every time.
      What you see in the picture happens only at the end of the static image, but disappears as soon as the boot screen appears, and so far has not been noticed during playback.
      Should I be worried????????
      I got the Vorke Z6 3GB Ram/32GB internal. I have the same issue.
      The boot up got the same issue as your pic. I was advised by my seller to do a factory reset. Its OK for a few days then the problem / symptoms of the artifacts came back again.
      Only the boot up shown this issue, should i be concern too? Did you manage to resolve this with the latest unroot rom or other custom rom? Thanks!
        Can someone tell me please, is there any way to activate the internet connection after the tv box going to sleep?
        When I'm turning off my tv the tv box also turning off but to sleep mode, the problem is that when I'm turning on the tv box the internet connection not working and I must reboot the box for making the internet working again.
          guys can you turn on / power on this tv-box using remote ?
            Yes.
            Unless you flash the ROM with another box's stock ROM.
              Does anyone know of a good remote with a keyboard that works with this box + LibreELEC?
                Is librelec requiring any special remotes?
                Because for Android boxes all airmouses are compatible.
                Sent from my ONEPLUS A3003 using Tapatalk
                  hi, how is your box, mate? working nice?? very hot?
                    It's working 24/7 in a perfect condition.
                    Regarding temperatures, I have made some comments at the related Tanix thread about how Terrarium is the best way to keep them down.
                      guys do you tick erase bootloader when flashing firmware to this tv-box ?
                      update
                      Vorke Z6 for 60.99$ with coupon code geekbuying
                      Vorke Z6 Plus 50.99$ with coupon code geekbuying
                      plus 8% cashback https://www.expressbonus.com/en/shop...geekbuyingcom/
                        I bought in 29.11.2017, a Vorke Z6 plus.
                        I used it very little - in 29.11 and 30.11.
                        In 01.12.2017 (after 2 days) , when I started it, tv box is blocked in boot sequence and on the screen it is attached image. I stopped and tried again – the same problem. Do not respond to remote, reset or power button. It is totally blocked.
                        Please see picture.Click image for larger version
                        Please help to solve this - it is a software issue that can be solved?
                        Or it is a hardware problem and the unit must be replaced?
                          custom rom for this tv-box http://4pda.ru/forum/index.php?showt...ost&p=67416372
                            There is an official ROM also on Vorke site, but main problem is if this issue is software or hardware. I do not know how to flash new ROM if the unit is totally blocked ( no reaction to any button)
                              Load the image to a SD card. Boot with the card in the sd card reader of the box. Hold down the reset button for 30 seconds after you see updating .
                              Then let it go and let it load.
                                thank you very much, in this way if I can connect to the computer.
                                but now it fails to load the firmware:
                                [15:47:21 646][HUB3-2][Err]--[0x10105002]Romcode/Initialize DDR/Read initialize status/USB Control setup error
                                [15:47:21 646][HUB3-2][Inf]--Close device handle 0x00000304
                                I already had this error before, it is only removed when I uncheck the boxes Erase flash and Erase bootloader.
                                that made bad firmware loaded.
                                any solution?
