BTW, I received mine after almost a month, and I was keep contacting Geekbuying, but with no answer, and finally I was happy to receive it.
VORKE Z6 Android 7.1.2 Amlogic S912 TV BOX 3/32GB eMMC5.0 WIFI BT Gig LAN
"mistag- greetings. I am very sad that the Z 6 does not have a USB 3.0 interface on its motherboard. As I decided to buy a 1980x1080P 4K recorder with USB 3.0 pendrive port for recording purposes, I must pray the gurus to enlighten the new comers
how to bypass that obstacle. Z6 appears to be a tough 'gibraltar' rock. Hope new users will not experience serious problems.
If you happen to find a 'means' or a solution how to get my USB 3.0 recorder to work hand-in-hand with Z 6 , please let me know. It would be 'MARVELOUS'. rgds
Originally posted by kwabh View Post"mistag- greetings. I am very sad that the Z 6 does not have a USB 3.0 interface on its motherboard. As I decided to buy a 1980x1080P 4K recorder with USB 3.0 pendrive port for recording purposes, I must pray the gurus to enlighten the new comers
BTW, how do you record from Vorke? Do you use an android app? If yes, which one?
Originally posted by Deon10 View PostAnyone figure out how to prevent the box from booting into the Vorke launcher?
I set up another launcher as the one to be the default one, but every time I turn off the box and turn it back on, it keeps going to the Vorke launcher.
Thank you
Yeah Play Store doesn't update on my Tanix TX92 running the Tanix firmware or the Vorke firmware.
I tried sideloading it by downloading it from apk mirror, but it says the file may be corrupt.
Latest version should be 8.4x or 8.5x. Latest Vorke firmware (the one without root access) is running 8.3x, and the original Vorke and Tanix firmware are running 8.0.26.
I also find it really irritating that Vorke modified chrome to always open the Vorke website in a new tab, EVERY TIME you open chrome.
Originally posted by rahzel View PostYeah Play Store doesn't update on my Tanix TX92 running the Tanix firmware or the Vorke firmware.
anyone successfully rooted 20171110 firmware ?
i tried Magisk 14.0 and 14.5 beta no luck (Failed to find META-INF/com/android/metadata in update pacakge)
Error in /data/cache/update.zip
(Status 127)
then i tried supersu Latest(V2.82): Recovery Flashable.zip
BAD RECOVERY DETECTED, NO UNZIP, ABORTING
(status 1) no luck as well
i used backup&update app
btw here is russian custom ROM
There are currently 2341 users online. 5 members and 2336 guests.
