VORKE Z6 Android 7.1.2 Amlogic S912 TV BOX 3/32GB eMMC5.0 WIFI BT Gig LAN
Originally posted by Jancales View Post
No idea about that.
I have also 1080p 50hz set as screen resolution on all my boxes, as it reduces Kodi - CPU load by about 25% compared to when it is set at 1080p 60Hz.
In Vorke I have auto 1 enabled, and that worked well. Auto 2 is also not liked by my tv.
Originally posted by JoseM View Post
i recommend you flash [ROM] Vorke Z6 / Tanix TX92 Stock & Nano Nexus ROM (Android 7.1) firmware works much much better than stock
Reporting back after more trials and errors. I tried the Nexus Roms as well and both were GREAT but neither fix the codec issue, specifically, with the Spectrum TV app. None of the playback, display, nor orientation settings fix the playback on ANY Android 7 rom. 1 nor 2 make any difference in the playback settings. The Spectrum TV app has an incorrect aspect ratio and the streams are pixelated badly on every revision of the stock 7 roms I've tried. I'd imagine similar apps having the same playback issues.
For those that can't live with the playback issues I'd recommend going back to Android 6 if possible. The TX8 (not Max) firmware might work on TX92/Z6 as the reverse is true. 17.6 works great on the 6.0 rom after uninstalling the stock and replacing with the Play Store version, though I haven't tested DTS audio. If it wasn't for not being able to live without the Spectrum TV app, I think the Nexus stock 7 roms are by far the best roms for Tanix/Vorke boxes at the moment in terms of stability and overall playback.
I'd try the stock 6.0 rom on the TX92/Z6 but don't have one to test. Still using the TX8 (not max.) If anyone could test a 6.0 rom on TX92/Z6, it might help others who are having similar issues.
The latest Marshmallow firmware I can find for ap6255 is here: https://www.chinagadgetsreviews.com/...-tv-box-3.html
For qc9377, here: https://www.chinagadgetsreviews.com/...x8-tv-box.html
The remote still works for me on Nougat roms, as well as bluetooth controllers, etc. so I'm sure your remote would work with the Marshmallow roms too if they can be flashed to your TX92/Z6.
Originally posted by StelioKantos View PostReporting back after more trials and errors. I tried the Nexus Roms as well and both were GREAT but neither fix the codec issue, specifically, with the Spectrum TV app. None of the playback, display, nor orientation settings fix the playback on ANY Android 7 rom. 1 nor 2 make any difference in the playback settings. The Spectrum TV app has an incorrect aspect ratio and the streams are pixelated badly on every revision of the stock 7 roms I've tried. I'd imagine similar apps having the same playback issues.
After you have installed Kodi, have a look at the system info in Kodi.
With other brand boxes I had the experience that there are some Kodi system files installed, and when you install Kodi they become active.
Don't know if this is the case with Tanix, but I have noticed this with a few boxes lately.
If these system files are installed you will notice during Kodi setup that settings like "expert" or " unknown sources" are already enabled by default.
With Vorke in Kodi system info it also shows Kodi version Kodi 17.6 xx-xxxx-xxxx Dirty.
Originally posted by zabba View Post
Hi, ive been having issues with kodi playing live tv (jumpy playback) when i get in from work im going to uninstall the pre installed kodi and add the play store version. Is there kodi files hidden that modifies kodi on install, if so will i be able to erase them before installation? Thanks
Take a look in data/data/ apps, or one of the other subfolders in data/data that have app in the name, and see if you find something with the name xbmc/kodi
Cheers looked in there and searched for kodi and xbmc on the file manager and nothing showed up. Ive added the playstore version now but iptv is still jumpy so think im admitting defeat with it so ill use spmc for iptv and kodi for addons.
Ugoos AM3 firmware may work as well not tested
TX8 MAX 2/16 ap6255 official firmware: http://www.tanix-box.com/download-vi...21-full-image/
I will try it later! Thanks. I also tested TX8 MAX 6.0 firmware for 3/16 ap6255 and it worked on TX8 (not max) 2/32. May work on TX92/Z6 as well and it's dated 0321. It works very well for me and the Microsoft Launcher completes it with that Nexus rom look and is highly customizable. Thus far everything works very well with this rom.
TX8 MAX 2/16 ap6255 official firmware: http://www.tanix-box.com/download-vi...21-full-image/SDRAM DDR3 2GB (compatibility 1GB-2GB) WIFI Module LTM8830
Don't really get why you would need both. If SPMC plays well for live tv, it will play as well for movies.
Hi all,
can anyone suggest or tell me if there is a unroot stock firmware for Vorke Z6 based on last firmware released (VORKE-Z6-20171221)?
Thanks.
Regards
There are currently 2122 users online. 0 members and 2122 guests.
