VORKE Z6 Android 7.1.2 Amlogic S912 TV BOX 3/32GB eMMC5.0 WIFI BT Gig LAN
Today I tested my new Vorke z6 for the first time and I was disappointed in few thing: the icons are small, some screens having options hidden off my TV screen (I tried to change the vorke screen size and change the resolution but didn't work), and Kodi is not loaded with add ons (my TX2 Kodi has many nice add ones) so is the new software has a solution for any of those issues?
I just noticed in the Geekbuying website, it mentioned that Kodi is preloaded with add ons, but not mine.
What is the difference between the regular and the plus? Mine is 3gb/32gb DDR4.
Updated info fixed:
As Found not tested
VORKE Z6 ANDROID 7.1.2 S912 3GB/32GB TV BOX FIRMWARE UPDATE 20171221
http://www.mediafire.com/file/g5mlyl...0171221-PC.zip
http://www.mediafire.com/file/ai2mmq...0171221-SD.zip
Change log:
1. Improve WIFI throughput, optimize network speed.
2. Repair automatically restart and crash.
3. Repair blurred image when booting.
4. Unlock Vorke launcher (User Choice can be in the Set -> HOME options select android native launcher to start).
5. Add ROOT switch to Set (set to be restarted to take effect).
6. Add video playback frame rate adaptive switch to Set, off by default.
7. Update Chrome browser to solve the situation which the old version of some websites can not pop up the soft keyboard.
8. Add ariscreen apk, support airplay IOS 11 version, chromecast and so on.
9. Remove the speed test app and update the KODI software version to 17.6.
Source: http://blog.geekbuying.com/2017/12/v...date-20171221/Last edited by trebor; 27 December 2017, 19:03.
VORKE Z6 ANDROID 7.1.2 S912 3GB+32GB/3GB+64GB TV BOX FIRMWARE UPDATE 20171221
change log:
2. Repair blurred image when booting.
3. Unlock Vorke launcher (User Choice can be in the Set -> HOME options select android native launcher to start).
4. Add ROOT switch to Set (set to be restarted to take effect).
5. Add video playback frame rate adaptive switch to Set, off by default.
6. Update Chrome browser to solve the situation which the old version of some websites can not pop up the soft keyboard.
7. Add ariscreen apk, support airplay IOS 11 version, chromecast and so on.
8. Remove the speed test app and update the KODI software version to 17.6.
PC
SD
source: http://blog.geekbuying.com/2017/12/v...date-20171221/
Originally posted by trebor View PostAs Found not tested
VORKE Z6 PLUS ANDROID 7.1.2 S912 3GB/32GB TV BOX FIRMWARE UPDATE 20171221
Change log:
Source: blog.geekbuying
Originally posted by JoseM View PostVORKE Z6 ANDROID 7.1.2 S912 3GB+32GB/3GB+64GB TV BOX FIRMWARE UPDATE 20171221
change log:
PC
SD
1. On the Vorke official site the update for the Z6 Plus is posted. There is no update for the Z6.
2. The file is the exact same files as for the Z6 Plus. I would have expected at least a few bytes difference.
Originally posted by Jancales View Post
I would be very wary about this update file for the following reasons.
I will flash one box in the next few minutes.
Just tried online update and it says my September 6 version is the latest.
there will be OTA update as well
Also in the backup&update app pressing online update said my current version was update.
Just flashed with usb burning tool, and with normal erase enabled it would time out after stalling at 7% download for more than 2 minutes.
Error receiving command / time out
Tried 3 times.
When I enabled force erase all it would complete.
I know, but i was thinking about a system update in Android settings / about.
Tried 3 times.
Tried 3 times.
There are currently 2106 users online. 2 members and 2104 guests.
