VORKE Z6 Android 7.1.2 Amlogic S912 TV BOX 3/32GB eMMC5.0 WIFI BT Gig LAN
damn vorke engineer really messed up with latest firmware issues are reported in other thread here http://freaktab.com/forum/tv-player-...718#post703718 and http://freaktab.com/forum/tv-player-...608#post704608
Originally posted by JoseM View Postdamn vorke engineer really messed up with latest firmware issues are reported in other thread here http://freaktab.com/forum/tv-player-...718#post703718 and http://freaktab.com/forum/tv-player-...608#post704608
Hi, im looking at buying this box in a few days. Is the general consensus that its a box worth buying? Ive read every post in this thread and have noticed quite a few issues about overheating which im not too worried about because ive got a usb fan which considerably lowered the temperature of my mecool m8s pro plus that ran very hot. Does adjust display refresh rate work on kodi with this box? Thanks.
Originally posted by zabbaHi, im looking at buying this box in a few days. Is the general consensus that its a box worth buying? Ive read every post in this thread and have noticed quite a few issues about overheating which im not too worried about because ive got a usb fan which considerably lowered the temperature of my mecool m8s pro plus that ran very hot. Does adjust display refresh rate work on kodi with this box? Thanks.
Sent from my ONEPLUS A3003 using Tapatalk
Originally posted by RASTAVIPER View PostDon't know about this one, but TANIX TX92 , which is the same box, has reduced the high temperature at KODI, so now it's even better.
If you look into the system info in Kodi you will see that it is a Kodi "dirty" version, which means they have added advanced settings that reduce GPU usage.
Originally posted by Jancales View Post
Same with Vorke, because they installed a modified Kodi.
The latest update has no Kodi at Tanix, so I have installed the latest Official by play store.
So, we have both the official updates available and lower temp.
Originally posted by zabba View Post
Hi, I've ordered the vorke today. Is it worth using the modified version of kodi pre installed or has the advanced settings taken away from the performance to reduce the running temperature? I have got a usb fan that can go on top or underneath the box, is there any vents at all on the top and bottom or are they all at the side? Thanks
There is no advanced settings file as explained in the wiki, so I assume they entered them in the GUI xml.
With the latest Vorke firmware there are also frame switching settings in the playback settings menu in Android system settings
My temps in the official Kodi app have been mostly the same, regardless of what firmware I use. It can run a bit warm after streaming 1080p for >1 hour, but I don't think it has caused any issues for me.
And if anyone is concerned about temps on these boxes, I find that it's better to stand the box vertical on its side so the vent holes are on the top. It blocks the bottom holes, but obviously heat rises and it does a more efficient job of exhausting the heat.
But again, I don't really have any issues with heat, so I just leave mine horizontal. Just thought I'd test for the hell of it.
There are currently 1546 users online. 0 members and 1546 guests.
