VORKE Z6 Android 7.1.2 Amlogic S912 TV BOX 3/32GB eMMC5.0 WIFI BT Gig LAN
Originally posted by miss
I have the same problem and the box just restarted, if you know of any solution warn me
I know some people that like the heat everywhere around them and with a room temperature at 27 degrees all electronic devices can be affected.
Unleashed by ONEPLUS 3T rooted
Originally posted by RASTAVIPER View PostWhat is the usual temperature of your box and what is your room temperature?
You will say you can switch on aircon, which of course I do, but anything below 26°C is freezing and you need a coat. Don't ask me why this is, as I am a westerner,and I know in the west 20°C is a comfortable temperature.
That said, I have S905 boxes and in the very same ambient temperature they ever go above 65°C, while S905X boxes also reach temperatures above 80°C easily.
What I found is that with Android 7 at around 83°C the box will lock up, while with Android 6 this isn't an issue on the very same box.
With Android 6 it will bring down the frame rate to around 40fps and stabilize the temperature, but I don't know why Android 7 doesn't handle this the same way.
Unfortunately for the Vorke Z6 I'm not aware of a Android 6 firmware been available anywhere.
The other question is, and I have asked this elsewhere but didn't get an answer, if a 83°C operating temperature is sustainable.
my room temperature is 24 degrees
I have to open the box so it does not restart
I'm not buying a fan, what I'll do is return the box, two boxes I bought and buy another box with another processor, a pity that it works very well but if I buy something it is for it to work, neither gekbuying nor vorke have answered me my mail
I noticed a difference of almost 20 degrees, when I use Kodi and when I use Terrarium for watching series and movies.
Kodi is very heavy on CPU usage and heats up quickly.
The overheating issues I reported are also only with Kodi. When using Android apps the problem doesn't exist.
and could you test this app, if the temp also go high, thanks
i use movie hd (necessary v-player from google store) without any issues on my alfawise h96 pro+ with normal temperature.
here you have some more good players
http://everyday-tech.com/top-20-free...s-ios-android/Last edited by tombraga; 14 November 2017, 15:19.
Originally posted by tombraga View Post
RASTAVIPER so your Tanix TX92 also get hot with Kodi playing, how much ºC?
By the way, I canceled my order of the Vorke 6 after reading about so many heating problems and got already my PayPal refund.
There are currently 2894 users online. 0 members and 2894 guests.
