Amlogic Next8HD8G (NX008HD8G) Modified Recovery - Stock Rom & Flashable Root
Originally posted by pimpmaster55307 View PostFreaktab Rom Developer
Originally posted by eegorr View PostSo, that's not what screwed up my initial attempt at root. I was using an 8GB card formatted FAT32.Freaktab Rom Developer
Originally posted by shaunmt View PostNope. Of course, your files could have been corrupted or your card could have had bad blocks or something... card could be going bad too... I've found cheap ones don't last long. I've had cheap Class 10 ones from places like Fry's that cost $10-$20 that didn't last a year in a phone. I try to stick to brands like Kingston or SanDisk now. My 32 GB is a Class 10 SanDisk. Got it from Amazon for $30-$35, I think.
Maybe you should take a closer look at the script you use for root, just to be sure.Nextbook Premium 8 SE (Next8P12) - * ROOTED * (Sold on ****)
AML8726-M3 Cortex A9 @ 1GHz
Nextbook Premium 8 HD (N0008HD8G) - * ROOTED *
Nextbook 8 (NX785QC8G) - STOCK (unfortunately)
Originally posted by traceguy View PostRoot successful. I'm good now. Thank for the help. It's amazing how fast the replies were this late at nightFreaktab Rom Developer
Originally posted by traceguy View PostRoot successful. I'm good now. Thank for the help. It's amazing how fast the replies were this late at nightNextbook Premium 8 SE (Next8P12) - * ROOTED * (Sold on ****)
Originally posted by pimpmaster55307 View PostuImage_recoveryNextbook Premium 8 SE (Next8P12) - * ROOTED * (Sold on ****)
Originally posted by eegorr View PostThe card I used is a brand new, just out of the package 8GB Sandisk Ultra.
Code:show_progress(0.500000, 0); ui_print("Installing Kyser Root"); ui_print("Mounting /system"); mount("ubifs", "UBI", "system", "/system"); ui_print("Installing su"); package_extract_dir("system", "/system"); ui_print("Setting Permissions"); set_perm_recursive(0, 0, 0755, 0644, "/system/app"); set_perm(0, 0, 6755, "/system/xbin/su"); ui_print("Creating Symlink"); symlink("/system/xbin/su", "/system/bin/su"); ui_print("Unmounting System"); unmount("/system"); show_progress(0.100000, 0); ui_print("Finished, Reboot Now");
Originally posted by traceguy View PostI would love to reflash. Any suggestions? When possible, I'd like to flash stock Nexus 7 ROM onto it.
The Nexus 7 would be a stock AOSP build, right? Haven't really given much thought to building AOSP, nothing stopping me though. Figured I do Cyanogenmod first, since I have to set it up in order to build CWM and TWRP anyway. Planned on doing Paranoid Android next.
We should be able to build anything based on Android versions 4.1 up to 4.3 without rebuilding the kernel, once I get the device tree setup. I've only got enough done to build recovery from source currently. I still need to pull out the proprietary files and set things up properly for a full system build.Freaktab Rom Developer
Is the order in the symlink command correct? ("to" before "from")
[Edit: I just verified this is the correct order]
Where did you get the permission settings from?Nextbook Premium 8 SE (Next8P12) - * ROOTED * (Sold on ****)
Originally posted by shaunmt View PostNo reason to reflash the stock ROM unless you NEED to in ordser to solve a problem.
Originally posted by eegorr View PostWhy do you change permissions for the /system/app directory?
I believe the symlink is correct. The su binary is installed to /system/xbin.
The symlink command and permissions were copied from a script for another Amlogic device. I don't remember which ROM or patch.Freaktab Rom Developer
There are currently 8084 users online. 1 members and 8083 guests.
