Amlogic Next8HD8G (NX008HD8G) Modified Recovery - Stock Rom & Flashable Root
Updated the stock ROM. Check the OP for details.Freaktab Rom Developer
Originally posted by gimgimp View PostI just flashed my nx008hd8g with the updated files. I have hdmi out using unis beta and mxplayer. Looking foreward to your other mods on this system!
It may be awhile before my next release, but it will be epic!
ShaunMTFreaktab Rom Developer
Originally posted by gimgimp View PostMay have spoken too soon. Worked great at first, then pauses. Checking wifi at that time shows signal strength poor. Canceling out of wifi makes signal strength normal.
Originally posted by Rabid1 View PostIf cancelling out of wifi and going back makes the signal strength better, try deleting system cache.
I've been staring at source code too long tonight... I think I'm gonna play some xbox and then call it a night.
ShaunMT
Originally posted by gimgimp View PostSorry about that, meant to say that hdmi output while streaming video caches. Checking wifi at that time shows poor signal.
My Next8P12 streams perfectly once the HDMI signal is properly synced. (Sometime have to unplug and replug a few times first) I normally have a very strong WiFi signal on all my devices though.
I'll report results of my Next8HD8G if I manage to get it replaced.
I have a romdump of my previous system and have converted it to the update zip. Build prop shows a later build number. I was wanting to see if the issue with wifi was present on a later build. I am having problems getting the signature to verify. I have used jarsigner, testsign, zipsigner.apk with testkey. No success. Could you point me to a post or prog to sign the zip for use in this updater?
Originally posted by gimgimp View PostI have a romdump of my previous system and have converted it to the update zip. Build prop shows a later build number. I was wanting to see if the issue with wifi was present on a later build. I am having problems getting the signature to verify. I have used jarsigner, testsign, zipsigner.apk with testkey. No success. Could you point me to a post or prog to sign the zip for use in this updater?
Originally posted by shaunmt View PostI don't recall where I got my signing script. If you want to upload it to drop box or google drive and point me to it, I'd be happy to zip and sign it and re-upload it.
ShaunMT
There are currently 2049 users online. 1 members and 2048 guests.
