Amlogic Next8HD8G (NX008HD8G) Modified Recovery - Stock Rom & Flashable Root
Originally posted by gimgimp View PostHere is the link to the romdump
https://www.dropbox.com/s/0kmdhzbvdp7g378/romdump.zip
ShaunMTFreaktab Rom Developer
Originally posted by gimgimp View PostThat problem is fixable by clearing system cache, had it after flashing an update. I can't remember my original build date, just had checked it before flashing.
Backup system
Originally posted by gimgimp View PostFinally got it to sign. My problem was the zip was too large. I split it up into smaller numbered updates and signed them. The updates flashed sucessfully! Typing from it now. Build number JRO03c.v009. Audio seems to be fine, tested a video and playback was normal.Archos Gen9 A80S cm-11.0
Kindle Fire 2 cm-11.0
ShaunMT
P.S. I installed it using TWRP on my tablet...Freaktab Rom Developer
Originally posted by stevemp View PostIt is the same build that came on my tablet. I have used ES File Explorer to remove some system apps and it feels faster and very smooth. What is the best way to make a backup of system and make a flashable restore image?
Alternatively, you could use a program like oNandroid to make a nandroid backup, but you can't restore a nandroid backup without a custom recovery like CWM or TWRP.
I expect to release a TWRP version for our tablets soon, but I'm not yet sure if nandroid backup and restore will work with the stock UBIFS file system. It might only work for custom ROMs with EXT4 file systems.
Originally posted by Rabid1 View PostNot sure what signer you are using, but look at the commandline and where it says 1024, increase it to 2048. if 2048 is laready there increase it to 3072.
Originally posted by unseeingdog View PostI am also getting Th3rdborns problem yesterday i had subway surfers and candy crush and now it says its not compatible with my device after i installed the stock rom and also when i turn on wifi the tablet freezes and restarts.
I think I will update my ROM descriptions too. The ROMs I currently have posted don't offer any new features. They are just for people who have installed an incompatible ROM or need to restore the stock ROM for some other reason.
For those of you who installed my ROM in the OP for the Next8HD8G. There are definitely two or more versions of this tablet. The romdump that gimgimp provided has a newer revision date, some system folder changes and apparently some kernel/boot/recovery changes as well. I installed it on my tablet and now the WiFi doesn't work and neither the internal nor the external SD card are mountable when the tablet is fully booted.
Thankfully, I can still boot custom recovery from external SD card, but I can't seem to reflash my previous stock ROM successfully. I'm going to have to spend some more time comparing the partition images file by file to determine the differences and then upload different versions to choose from.
It would help if everyone could advise what their Model is, their manufactured date, which ROM they are currently using (Original Stock or which one they flashed), their kernel version, build number and build revision date(from build.prop). If you're using a ROM that you flashed advise what doesn't work.
build.prop
can someone please send me a copy of your build.prop, im running through some compatibility problems here my gmail is [email protected]
Originally posted by unseeingdog View Postcan someone please send me a copy of your build.prop, im running through some compatibility problems here my gmail is [email protected]
There are currently 2828 users online. 0 members and 2828 guests.
