Amlogic Next8HD8G (NX008HD8G) Modified Recovery - Stock Rom & Flashable Root
Originally posted by unseeingdog View PostFreaktab Rom Developer
Fixed WiFi and SD Card mounting problems
I managed to fix my WiFi and SD mounting issues. It seems they were just a result of a bad flash, in my case this may been related to my ongoing testing with TWRP. Simply reflashing did not solve the issues which was surprising considering the install reformats almost everything.
Here is how i fixed it...
I reformatted my external sd card in my laptop.
Put fresh copies of the mod 3e recovery and stock rom on the external sd card.
Rebooted to the mod 3e recovery.
Did wipe data / factory reset.
Did wipe cache.
Did wipe media.
Reflashed the stock ROM.
I will have to do more testing before updating any files. I am still not sure how many differences are in the different ROM revisions. Also i dont have the newer bootloader for the newer ROM revision.Freaktab Rom Developer
If it helps, mine is stock but, deodexed and the default.prop in bootimg edited for full adb with ro.secure=0. My build prop is identical to gimps.
Originally posted by Rabid1 View PostIf it helps, mine is stock but, deodexed and the default.prop in bootimg edited for full adb with ro.secure=0. My build prop is identical to gimps.
I'm trying to determine when any hardware changes occured, so I can advise people which tablets the ROMs will work on.
ShaunMTFreaktab Rom Developer
Originally posted by shaunmt View PostWhat is the manufacture date? Should be a sticker on the back of the tablet. Should be on the box too, if you still have it.
ShaunMT
Originally posted by gimgimp View PostMy build date on the box states "manufactured april, 2013".
Anyone got one made later than April?Freaktab Rom Developer
Date
My says Manufactured May 3013 on the box but it's the same build as Apirl.Code:# begin build properties # autogenerated by buildinfo.sh ro.build.id=JRO03C ro.build.display.id=JRO03C.v009 ro.build.version.incremental=eng.root.20130402.204838 ro.build.version.sdk=16 ro.build.version.codename=JellyBean ro.build.version.release=4.1.1 ro.build.date=Tue Apr 2 20:49:15 CST 2013 ro.build.date.utc=1364906955 ro.build.type=user ro.build.user=root ro.build.host=midcs-desktop ro.build.tags=release-keys ro.product.board=NXM8000ND_WM ro.product.model=NX008HD8G ro.product.brand=Nextbook ro.product.name=NX008HD8G ro.product.device=NX008HD8G ro.product.cpu.abi2=armeabi ro.product.cpu.abi2=armeabi-v7a ro.product.manufacturer=YIFANG ro.wifi.channels=14 ro.board.platform=meson6 # ro.build.product is obsolete; use ro.product.device ro.build.product=NXM8000ND_WM # Do not try to parse ro.build.description or .fingerprint ro.build.description=NXM8000ND_WM-user 4.1.1 JRO03C eng.root.20130402.204838 release-keys ro.build.fingerprint=Nextbook/M8000ND/M8000ND:4.1.1/JRO03C/v009:user/release-keys ro.build.characteristics=tablet # end build properties
Archos Gen9 A80S cm-11.0
Kindle Fire 2 cm-11.0
Originally posted by stevemp View PostMy says Manufactured May 3013 on the box but it's the same build as Apirl.Code:# begin build properties # autogenerated by buildinfo.sh ro.build.id=JRO03C ro.build.display.id=JRO03C.v009 ro.build.version.incremental=eng.root.20130402.204838 ro.build.version.sdk=16 ro.build.version.codename=JellyBean ro.build.version.release=4.1.1 ro.build.date=Tue Apr 2 20:49:15 CST 2013 ro.build.date.utc=1364906955 ro.build.type=user ro.build.user=root ro.build.host=midcs-desktop ro.build.tags=release-keys ro.product.board=NXM8000ND_WM ro.product.model=NX008HD8G ro.product.brand=Nextbook ro.product.name=NX008HD8G ro.product.device=NX008HD8G ro.product.cpu.abi2=armeabi ro.product.cpu.abi2=armeabi-v7a ro.product.manufacturer=YIFANG ro.wifi.channels=14 ro.board.platform=meson6 # ro.build.product is obsolete; use ro.product.device ro.build.product=NXM8000ND_WM # Do not try to parse ro.build.description or .fingerprint ro.build.description=NXM8000ND_WM-user 4.1.1 JRO03C eng.root.20130402.204838 release-keys ro.build.fingerprint=Nextbook/M8000ND/M8000ND:4.1.1/JRO03C/v009:user/release-keys ro.build.characteristics=tablet # end build properties
Originally posted by Rabid1 View PostMine is April too.
Sometimes in the OS build you may have two build dates to signify the retailer. Mine was a Walmart purchase.
Originally posted by androidgbear View PostHello, Worked like a charm! I would like to know how to dump the rom now so I can reflash it if I need with the changes I have made. Thank You for your work!
Originally posted by gimgimp View Postshaunmt, I have the original bootloader.img that i dd'd from my stock system. If this can help, I will upload it for you.
Originally posted by shaunmt View PostIt might. At least we'd know we the entire package for the newer revision date. ShaunMT
There are currently 2284 users online. 1 members and 2283 guests.
