Bluetooth would be nice - something that is sorely lacking on this tablet. I wish they had left off the second camera and added bluetooth instead.
Amlogic Next8HD8G (NX008HD8G) Modified Recovery - Stock Rom & Flashable Root
Originally posted by shaunmt View Post
Bluetooth would be nice - something that is sorely lacking on this tablet. I wish they had left off the second camera and added bluetooth instead.Nextbook Premium 8 SE (Next8P12) - * ROOTED * (Sold on ****)
AML8726-M3 Cortex A9 @ 1GHz
Nextbook Premium 8 HD (N0008HD8G) - * ROOTED *
Nextbook 8 (NX785QC8G) - STOCK (unfortunately)
ok, so after a wipe/wipe/reflash x2
i tried a couple different things.
using my usb 3.0 port/s the tablet will 3% to full in just around 35 minutes.
using usb 2.0 port/s the tablet takes over an hour to 3% to full charge.
@ 50% battery i plugged the wall charger into the tablet, and gave it about an hour.
after the hour of "charging" i unplugged the tablet, only to see the red exclamation mark on battery, after which it immediately died.
only after plugging it back into my usb 3.0 port and letting it set for around 20 minutes, could i get the tablet to turn back on.
now it has been setting in sleep mode for around 2 hours, and as long as it is plugged in, it run fine, but the moment i unplug it, the battery runs at 0%
any other ideas?
any other ideas?
Re: Amlogic Next8HD8G (NX008HD8G) Modified Recovery - Stock Rom & Flashable Root
Originally posted by Rabid1 View Postso it is only doing this after the charger is used, or all the time now. If the battery IS charging off USB and holding when disconnected, but draining off the charger and not holding when uplugged after being charged for awhile then you might have a faulty charger. IF wiping the system or flashing a new ROM does not fix the problem I would try a new charger.
Sent from my SPH-L710 using TapatalkFreaktab Rom Developer
alright.
its holding a charge as long as i don't let the wall charger near it.
so i was wondering, do i still need to do another ROM flash, or should i just trash this wall charger and be happy with the usb?
also would you recommend me go with the newest ROM or the one i originally had flashed on it?
i ask cause if the newest ROM is in any way better, then i would want to use it while the Tablet is still a blank slate.
Originally posted by Micheal View PostHas there been any updates for this tablet yet? Life has gotten in the way of me working on this myself. Ill get back to it as soon as things settle down but if there is a good base to work off of that would speed things up considerably.Freaktab Rom Developer
I've actually already installed the stock Tom from nov and re-rooted everything. Seems to be working well. I understand about school work and life especially this time of year. And apparently need to tweak this keyboard as it is giving me a headache with its auto correct feature not working or its inability to keep the cursor in the same place.Last edited by Micheal; 23 November 2013, 07:29.
i can't get access to recovery mode in my nextbook premium 8 se
hello
Tahk you for having treated this thread because i didn't find any solution in the net and the only forum i feelt that he is good and i will find the help is yours so please i want your help.
I have nextbook premium 8 se and i use it well suddenly it shutdown and do not respond I did a long press on power but nothing i tried to do a reset with that little thing in the corner but nothing i tried to get access to recovery mode with pressing power and sound + but nothing it always blocked in the first logo. by the way my tab was rooted using the methode of shaunmt i used the modified recovery and the root package and it worked well with super su.apk.shoretly my nextbook premium 8 se c'ant boot can't have access to recovery mode to do a hard reset can't be open at all and stil freeze in the first logo until i long press the power so that it shutdown and the battery and tha charger ac worked well and the led also .
I followed many threads some use aml flach some use rk29upgrade.exe but my problem was that i didn't have a full rom package. also i tried to connect my tab with my pc so that i plug the usb and press power and sound - until my pc shows a new unknown device and failed in getting driver and in the device manager it shows M3-Chip after a long search i installed the driverlibusb-win32-bin-1.2.6.0 so my tab was named worldcup device but still not detected by aml flach and also rk29upgrade !!!!! I didn't know what should i do i am a beginner in android world so i reach these information after a long nights in the net so please i need your help guys i know that you can do it !!!
You flashed the tablet with the wrong rom you sound like you have a Next8P12 not a NX008HD8G
Take out the sdcard format it and put your stock rom zip onto it. Reinsert it and press power and VOLUME UP at the same time untill you see the first boot screen. Then release the power button but keep volume pressed until you hit the recovery screen. This can take a few seconds so be patient. At the recovery screen use the volume up and down to highlight menu items and the power button to select them. Choose the install from EXT option. Select your rom and follow your on screen instructions.
If that fails you will need
ADB
Drivers for your device
A copy of your stock rom {look for Next8P12 drivers and rom}
Basic knowledge of how to use adb
All is not lost, if your pc can see the device there is hope. You will need to use adb to reformat the tablet and then push the stock rom to it. Make absolutley sure you have drivers and rom that match your device. Your problem may have arisen from the fact that you do not have an nx008HD8G you have a Next8P12. By flashing the wrong rom you have given the device fits. As a general warning you must always know exactly what you have for a device. System architecture can vary wildly even within the same family of devices.Last edited by Micheal; 26 November 2013, 01:19.
Originally posted by Micheal View PostYou flashed the tablet with the wrong rom you sound like you have a Next8P12 not a NX008HD8G
ADB
There are currently 8096 users online. 1 members and 8095 guests.
