Amlogic Next8HD8G (NX008HD8G) Modified Recovery - Stock Rom & Flashable Root
Originally posted by lordboo03 View PostThe build date is Oct 28 2013
ShaunMTFreaktab Rom Developer
Good News For Bricked Tablets With The Newer Manufacture Dates
I've started reviewing the ROM dumps I received from the Next8HD8G tablets with the newer manufacture dates.
Sure enough, it looks like the internal components changed at some point.
The new bootloader is different, which is why the older ROM bricked some of your tablets.
The new bootloader bricked my tablet.
You guys who are bricked because you flashed the older ROM revision on a newer tablet are going to need an Amlogic Rescue SD Card with the new bootloader, a modified or custom recovery, and the new ROM to get your tablets working again.
I'll be posting unbrick kits to make the special SD card and the new ROMs soon. (I'll be posting every version I have for each tablet eventually, just in case some one needs a different revision date.)
Stay tuned...
Originally posted by Xeriios View PostHey again few days ago I bricked my October 2013 produced tab n I was still able to return it so if u want the 12/2013 built rom ill look over the dumping guide n get started just lemme know
Originally posted by Xeriios View PostThe tab build on 12/13 has build prop dated 10/28/13
I'm assuming it hasn't changed correct?Freaktab Rom Developer
BootLoader.IMG
Originally posted by shaunmt View PostI would assume the same. I think the 10/28/13 build is the newest. I will try to get a copy posted tonight or tomorrow.
Originally posted by locuraconsigueusted View PostProbably a stupid question, but... If it's the bootloader that changed, couldn't you just put the new bootloader in the old ZIP???
I'm working on getting it all packaged up. I'm also trying to finish up CWM and the unbrick kits... I want to post it all together so I don't have to rewrite the instructions later or answer so many support questions.
ShaunMT
P.S. It doesn't help that my hardware seems to be failing, which is making it extremely difficult to test.Freaktab Rom Developer
Originally posted by shaunmt View PostNot a stupid question. That would work, if it were just the bootloader, but it's also drivers and lib files and...
ShaunMT
Goid going with unbrick kits idea. Will make you the most popular guy for discount tabs. Glad you are working on thus still. I was going to try to get into it but I just don't have the time with a baby on the way and just don't have the time it woukd take to get to know everything id need to make a new rom from scratch on a tab with very little support other than you. Oh and a qquestion, is there a way to expand the internal storage partition and lower the sdcard partion? If so how? Not vold_swap as that switches the internsl and external sdcard from what I understand.
Originally posted by Micheal View PostGoid going with unbrick kits idea. Will make you the most popular guy for discount tabs. Glad you are working on thus still. I was going to try to get into it but I just don't have the time with a baby on the way and just don't have the time it woukd take to get to know everything id need to make a new rom from scratch on a tab with very little support other than you. Oh and a qquestion, is there a way to expand the internal storage partition and lower the sdcard partion? If so how? Not vold_swap as that switches the internsl and external sdcard from what I understand.
One idea I've considered testing, but haven't gotten around to yet, is to either swap the mnt points for /data and /sdcard. I'd rather have the larger partition as /data, but I'm not sure this will work because of the filesystems.
Another idea, would be to not mount the internal SD card at all. We would be sacrificing that storage space, but then we should be able to install apps on the external SD card. I'd happily give up the internal space to make more use of my 32 GB external SD card. Again, I have gotten around to testing this.
System TAR?
I had received the one from NeroWolf, but the archive was corrupt (probably because it was pulled with the dd if commands)Can anybody send me a stock system.tar pulled with the busybox tar command?
EDIT: Nevermind, I borrowed my sister's tab and pulled the partition myself.
Thanks,
locuraconsigueustedLast edited by locuraconsigueusted; 20 January 2014, 22:48.
There are currently 3003 users online. 4 members and 2999 guests.
