Amlogic Next8HD8G (NX008HD8G) Modified Recovery - Stock Rom & Flashable Root
Originally posted by Sumphlet View PostAny updates on the new ROMs for this tablet?
I started to upload these a few days ago, but I ran a final test for some last minute mods, and discovered some bugs in my installer and backup scripts...
I've got the backup working perfectly now, and I think I've narrowed the install problem. I've got a few days off work for comic con, so I should be able to get the installer working correctly and get these released before I go back.
It's currently skipping some of the binary files during install (like su for root). I believe the problem lies in the zip method I've been using, but further testing is necessary to confirm and correct the issue.
When these get released, you'll have slightly customized roms based on the 10/28/13 stock builds for both tablet versions. They will be pre-rooted, slightly debloated, deodexed, zip aligned and more...
You'll also be able to say goodbye to the Nextbook splash screens that everyone seems to hate so much... I hope everyone likes the new ones better!
ShaunMTFreaktab Rom Developer
Originally posted by locuraconsigueusted View PostWill it have init.d or will we have to enable it using term init, zip init, or uni init from XDA?
Sent from my Event using Tapatalk
Re: Amlogic Next8HD8G (NX008HD8G) Modified Recovery - Stock Rom & Flashable Root
Originally posted by roadkill View Postthat a good thing I m don't under Stanton why need it sorry I'm still clearing all of this
Sent from my SPH-L710 using TapatalkFreaktab Rom Developer
cwm
is tjere a easy way to flash cwm to the tablet rather to ext sd card i only have 2 gig one i like to change roms often like i do on my phone this way i can go to cwm on tad chose whitch one tjen it reboots and then installs tje room i chose easer for me and faster i dont plan on using any updates from nextbook
Use the flash_image from the link I sent you. Push it Or copy It to /system/bin and chmod 755 it. Then use terminal emulator or adb shell and type:
Su
Flash_image recovery /storage/sdcard0/external_sdcard/uImage_recovery
Hope this helps.
*NOTE*
If you experience issues, Shaun has already stated that he will not be supporting it directly on the tablet. I'm not sure if he will be true to that statement, but have a nandroid backup just in case.
Originally posted by locuraconsigueusted View PostUse the flash_image from the link I sent you. Push it Or copy It to /system/bin and chmod 755 it. Then use terminal emulator or adb shell and type:
Su
Hope this helps.
*NOTE*
There are currently 2821 users online. 1 members and 2820 guests.
