Amlogic Next8HD8G (NX008HD8G) Modified Recovery - Stock Rom & Flashable Root
so my tablet is rooted also with the newest stock rom update from you so now I can play all games from google play but now my sd card isn't found? when I hit storage in settings I get unfortunately settings has stopped every time. if I put the sd card in and out it says removing and preparing. is this a bug in the stock rom that needs to be updated by you? Pease Help! Thanks.
Stock Rom files from 9/30/2013
Hey shaun, I have a set of stock files from a nextbook nx008hd8g with a manufactured date of October 2013. and a build date of September 30, 2013 (according to build.prop). If I upload them to Google Drive, can you take a look at them for differences between the current July build and these? I figured this may help you for future stock roms and possible custom roms.
EDIT: Uploading as I type, will take a while though. I'll let you know through PM when it is done.
UPDATE: It's done. Sending PM now.Last edited by RosaFang; 03 December 2013, 03:33.NEXTBOOK NX700QC16G Rooted with updated firmware to allow 13GB App Space
Originally posted by truseq1 View Postso my tablet is rooted also with the newest stock rom update from you so now I can play all games from google play but now my sd card isn't found? when I hit storage in settings I get unfortunately settings has stopped every time. if I put the sd card in and out it says removing and preparing. is this a bug in the stock rom that needs to be updated by you? Pease Help! Thanks.
I would suggest, reformatting the SD card and wiping data and cache. If that doesn't solve the problem, flash the ROM again.
Also have you tried any other SD cards?
ShaunMTFreaktab Rom Developer
Originally posted by RosaFang View PostHey shaun, I have a set of stock files from a nextbook nx008hd8g with a manufactured date of October 2013. and a build date of September 30, 2013 (according to build.prop). If I upload them to Google Drive, can you take a look at them for differences between the current July build and these? I figured this may help you for future stock roms and possible custom roms.
Thanks again!
Originally posted by truseq1 View PostThanks wiping the data and cache worked! should you always wipe data and cache before a rom install or root? OR after? im pretty new to tablets but ive been building and modding computers for 16 years and i know nothing about coding so thanks for being patient!
I'm glad you solved your problem!
Originally posted by shaunmt View PostIt is often considered best practice to wipe data and cache once or even twice before and after a flash install. My ROM package actually wipes both once during the install process, but sometimes once just isn't sufficient on Android devices. The root package does not wipe anything because it only adds the su binary and sets permissions for it. "Dirty" flashes without wiping are convenient, but they are often the cause of many user complaints.
ShaunMT
Hi Im having issues flashing the stock rom. My serial build date is 1113. I tried flashing the root zip file. But it resulted in freezing at the at the second screen (woman with headphones) so I then used the stock rom to try and fix this "soft brick" situation, now it freezes at the 3rd bootload (rotating bubbles and finger).
I'm using a FAT formatted 2GB microSD. I tried downloading all your stock roms by dates that are included in your posts, none are working. Please help...
Originally posted by Jiero View PostHi Im having issues flashing the stock rom. My serial build date is 1113. I tried flashing the root zip file. But it resulted in freezing at the at the second screen (woman with headphones) so I then used the stock rom to try and fix this "soft brick" situation, now it freezes at the 3rd bootload (rotating bubbles and finger).
The newest firmware build date I have is 9/30/13. I'll try to get it tested and posted soon.
Re: Amlogic Next8HD8G (NX008HD8G) Modified Recovery - Stock Rom & Flashable Root
Thanks for your reply. Although with disappointment and returning the tablet, I will keep checking back to see updates about this cause I may get one in the future. I just couldn't deal with a sitting brick. And the one person that is supporting this thread on YouTube has a terrible explanation/tutorial (from what he calls his video)...
If it's of any relevance, yes they are manufacturing quite a lot. Walmart had 27 in one location and 5 left in the other nearby locations where I am.
Tablet no longer turns on!!!
I just got this tablet TODAY for Christmas and wanted to root it. Followed your directions and it went into a boot loop. So, I decided to flash your stock ROM. After some troubleshooting (file got corrupted in download) I redownloaded it and flashed again. Gave me a "successful, reboot now" message. I hit "reboot now" and it turned off. Haven't been able to turn it back on since. No power on at all, just a black screen. Help me PLEASE!
Originally posted by mcfly View PostI have a 1013 facing the same exact situation as Jiero...
Please provide as much information as possible about your tablet and packaging.
Originally posted by locuraconsigueusted View PostI just got this tablet TODAY for Christmas and wanted to root it. Followed your directions and it went into a boot loop. So, I decided to flash your stock ROM. After some troubleshooting (file got corrupted in download) I redownloaded it and flashed again. Gave me a "successful, reboot now" message. I hit "reboot now" and it turned off. Haven't been able to turn it back on since. No power on at all, just a black screen. Help me PLEASE!
Am I correct that your device won't boot into Android and also won't boot into recovery?
Originally posted by shaunmt View PostAre you sure your tablet is a Next8HD8G? Please provide as much information about your device and packaging as possible.
ShaunMT
It is a nextbook NX008HD8G with serial YFG101309... manufactured Oct 2013 (bought from walmart). Hope this helps and thanks again for your work.
Thanks for the help, but...
ShaunMT
Originally posted by cchomebrew View PostShaunMT - first off, thanks much for your development efforts here. I purchased a NX008HD8G earlier this year and rooted with no probs. I purchased another last week and applied the same procedure - froze on bootup (woman with headphones). I attempted to restore the stock rom and it's now completely black. No reset, no color, nada. I then found Jiero's response above and it looks like I did the same thing he did.
There are currently 2858 users online. 1 members and 2857 guests.
