Amlogic Next8HD8G (NX008HD8G) Modified Recovery - Stock Rom & Flashable Root
]How can we tell the difference (especially if we are bricked)
Originally posted by locuraconsigueusted View PostHow can we tell the difference (especially if we are bricked)?
Originally posted by jimbrook View PostIt will be shown as "build.prop" in the top level of the "system" file in the your root directory. Your root directory will be shown as the phone symbol when using Astro File Manager to search for the file. There is also a "default.prop" which (I think) mirrors the "build.prop." Of course, If you are bricked, nothing works. You can also tell, to the day, when the device was manufactured. Yifang, the manufacturer, also builds for Archos and several other well known European brands. Thanks for Shaun for the work. Please, oh please, come out with a mod that gets rid of the awful, tacky, OEM boot screen.
default.prop is inside the boot.img... you have to know how to dump and then unpack the boot.img to get to it.
I've asked Tattman to work on some custom splash screens, which I intend to use in all future ROMs, including stock based ROMs.
ShaunMTFreaktab Rom Developer
Unbrick Kits for Next8HD8G (both boards) Have Been Released
Unbrick Kits for Amlogic Based Nextbooks - Download Thread
Unbrick Kits for Amlogic Based Nextbooks - Support Thread
SD Card and Storage settings
shaunmt,
First, sorry for the cross post. I have a Next8HD8G, to which I just flashed the stock rom and the root package using the modified 3e recovery (all found here: http://www.freaktab.com/showthread.p...Flashable-Root). Now, I am unable to access the external SD card I have. When I put it in or remove it, I do get the notification, but when I go to storage settings, I get 'Unfortunately, settings has stopped'. Also, when I use ES File explorer, it says the SD card is unmounted. Do you have any idea why this is happening, and more importantly, what I can do to fix this? Please let me know when you can. Thank you.
Remove the external SD Card
Boot into stock internal recovery
Wipe Data (Twice)
Wipe Cache (Twice)
Reboot, verify Data and Internal SD Card mount correctly
Reinsert External SD Card
Verify External SD Card mounts correctly
If not...
Wipe Data (Twice)
Wipe Cache (Twice)
Wipe Media (Twice)
If not...
Reformat the external SD Card on a comptuter
If it still won't mount...
Reflash the ROM
Wiping usually solves this problem, although it does not always work on the first try.
Nextbook NX008HD8G, YFG0114005290, Bricked =(
Well first I attempted root par instructions on this model, the flash went smoothly, upon rebooting the tablet froze at the secound splash screen, I attempted re-flashing with the kyser zip still locked at the secound screen, so I decided too reflash the stok rom... it also installed smoothly but it killed the tablet it wont even turn on now... Im guessing i am SOL on this?
q
Originally posted by drandoss View PostWell first I attempted root par instructions on this model, the flash went smoothly, upon rebooting the tablet froze at the secound splash screen, I attempted re-flashing with the kyser zip still locked at the secound screen, so I decided too reflash the stok rom... it also installed smoothly but it killed the tablet it wont even turn on now... Im guessing i am SOL on this?
Re: Amlogic Next8HD8G (NX008HD8G) Modified Recovery - Stock Rom & Flashable Root
It sounds like you used the wrong version files.
You will probably need an unbrick kit and the rom I expect to post later tonight.
Sent from my SPH-L710 using TapatalkFreaktab Rom Developer
Originally posted by shaunmt View PostIf they are bricked, they can't boot to check those locations.
ShaunMT
Originally posted by BigEggy View PostIs there any other way to check which model I have. When I search inn astro for stock. Or default prop nothing it's found and I don't want to use the wrong one and brick my tablet
build prop
Originally posted by shaunmt View PostAssuming your tablet currently works normally, the easiest way is to download a build.prop editor from the play store. It will display the contents of your build.prop file. You can find the board id in any of the following fields: ro.product.board, ro.build.product, ro.build.description or ro.build.fingerprint
ShaunMT
There are currently 4234 users online. 0 members and 4234 guests.
