Does the Recovery that you created come with the devices and all the binaries that it needs or do I need to download those separately?
Amlogic Next8HD8G (NX008HD8G) Modified Recovery - Stock Rom & Flashable Root
Originally posted by BigEggy View PostDoes the Recovery that you created come with the devices and all the binaries that it needs or do I need to download those separately?
What exactly are you trying to do?
Is your tablet currently working normally or are you trying to fix it? If you are trying to fix it, what is wrong with it?
Are you just trying to root?
ShaunMTFreaktab Rom Developer
Originally posted by shaunmt View PostI'm not sure what you're referring to regarding devices and binaries, but I think you'll be fine with the recovery.
ShaunMT
Originally posted by BigEggy View Postyes just trying to root...but when I first started with this tablet...it said to download 3 file...stock, root, and binaries...but like I said it was for the older tablets.....so im sure once I put the ulimage file on sd card and put stock in folder on sd card then I will be ok incase I mess up I can boot back to stoc
Originally posted by BigEggy View Postwhenever you say flash...what exactly do you want me to do with the files?...run the..open them...and do I need a certain software to flash it?...just not quite sure what flash meant...sorry that im not currently up to par on these kinda things....but im trying to learn
In this case, you put the uImage_recovery on your external SD card then turn your tablet on and hold the power button and the volume- button until recovery starts. Our tablets automatically look for uImage_recovery on the external SD Card and use it instead of the stock internal recovery. This allows us to bypass the stock recovery which uses private security keys that we don't know.
To "flash", you choose install zip from SD (or something similar) then choose the kyser_root.zip (or whatever you're trying to install).
Also, be aware that the some of the files in original post of this thread are outdated... the kyser_root.zip from this thread is fine, but instead of the modified stock recovery, you should probably use the CWM recovery from here: http://www.freaktab.com/showthread.php?10341-CWM-Recovery-with-UBIFS-Support-For-Amlogic-Nextbook-Tablets-(Support-Thread)
Just make sure you get the CWM version that matches your board.
recovery
Originally posted by shaunmt View Postflash means to install it using recovery...
ShaunMTok I did have the correct recovery....double checked with your link...now I have debugging on and sd mounted...is that correct....and is it volume up or volume down?
Originally posted by BigEggy View Postahhhhhh...ok..that i understand...lol...just not familiar with the term flash..but now I am..thank you for clarifying that for meok I did have the correct recovery....double checked with your link...now I have debugging on and sd mounted...is that correct.
Just follow my instructions...
turn the tablet off
remove external sd card
put external sd card in pc
copy uImage_recovery and kyser_root.zip to external sd card
remove external sd card from pc
insert external sd card in tablet
hold power and volume- on tablet until recovery starts
flash install the kyser_root.zip
reboot tablet
download your preference of superuser or supersu or something similar from play storeFreaktab Rom Developer
turn the tablet off
reboot tablet
-no
-yes-disable recovery flash
which one should I choos?
Originally posted by BigEggy View Postok....im trying to reboot....says ROM may flash stock recovery on boot. Fix?
-no
There are currently 2722 users online. 0 members and 2722 guests.
