Amlogic Next8HD8G (NX008HD8G) Modified Recovery - Stock Rom & Flashable Root
    After it is in /system/bin type su chmod 755 /system/bin/flash_image.
    If that does not work try chmod 777.
    Sent from my Event using Tapatalk
      Originally posted by locuraconsigueusted View Post
      *NOTE*
      If you experience issues, Shaun has already stated that he will not be supporting it directly on the tablet. I'm not sure if he will be true to that statement, but have a nandroid backup just in case.
      What he said ^
      ShaunMT
      Freaktab Rom Developer
        dreadful that anticipation is
          I'm just wondering if the everything is ok with you???? We haven't heard anything in a few days. Hopefully you are okay and are just busy elsewhere.
            Me?
            I've been around. Finally worked out the last bugs in my modified (stock based) ROM for the NXM8000ND_WM model. Going to try to package up the NXM8000NBD_WMN model today and maybe get them posted by tonight. No promises though... I've been ill the past few days so I may just crash when I get home.
            ShaunMT
              Originally posted by shaunmt View Post
              Me?
              ShaunMT
              Looking forward to finally seeing it, but hope you feel better and get some rest... I'll be glad to finally use my tablet as more than a paperweight.
                kyser download
                Everytime I download this zip file I immediately get the complete action using box, which has package installer and scan for viruses before installing as the choices. Even w/o choosing either one and getting out of that screen, it unzips the file and you see the apk file. How do I stop this from happening? I believe that because it was opened, the signatues are broken and that is what is causing my installation to abort.....How do I fix this? I never have that box appear w/ reg ..zip files, only the ones that contain an apk file
                  Originally posted by wiseman9871 View Post
                  Every time Iaunmt;118055]It is aborting during the signature verification, before the installation actually starts. Either the modified recovery isn't booting and the tablet is defaulting to the internal stock recovery, or the kyser_root.zip is corrupted.
                  Verify the uImage_recovery file is in the root level of the external SD card.
                  Put the kyser_root.zip in the root level of the external SD card also. Do NOT open the kyser_root.zip after you download, just opening can break the android signature.
                  ShaunMT
                  Everytime I download this zip file I immediately get the complete action using box, which has package installer an.d scan for viruses before installing as the choices. Even w/o choosing either one and getting out of that screen, it unzips the file and u see the .apk file. How do I stop that from happening? I think the sings are being broken and that's why my installation aborts.[/QUOTE]
                  i down loaded it using the tablet and then used a file manger to put were they need to b i use toatle comander works for me
                    In think you are correct, although I'm not sure what's causing it or how to avoid it...
                    Are you downloading it from the tablet? You might have better luck downloading it with a computer, copying it to the sd card with an sd card reader, then putting the sd card back in the tablet...
                    ShaunMT
                      In think you are correct,unfortunatelygh I'm not sure what's causing it or how to avoid it...
                      ShaunMT
                      Shaun, yes I am.An you are probably right. But unfortunately I don't have a working computer at the moment. The thought occurred to me that possibly I could get someone to email to me @ [email protected] that would also fix my problem
                        Stock rom for _WMN
                        Shaun do you have a stock for the wmn i need to use christian troys method to unbrick one of mine it wasn't even rooted so im unsure as to wth happened with it.
                        and to whom it may concern i still have had zero issues with the cydia impactor method of rooting on 2 seperate tablets for anyone considering it. although be weary your stock one may brick on its own
                          I'll be posting modified ROMs based on the 10-28-13 stock builds for both the WM and the WMN models tonight...
                          ShaunMT
                            ShaunMT
                            Tonight? Hehe
                              Originally posted by Sumphlet View Post
                              Tonight? Hehe
                              Well... They ARE on the server... but I fell asleep while they were uploading...
                              I'll be typing up the posts shortly...
                              ShaunMT
                                ShaunMT
                                Yippee
