Amlogic Next8HD8G (NX008HD8G) Modified Recovery - Stock Rom & Flashable Root
Originally posted by SprayStupid View PostIs there a thread with the build.prop edit to allow incompatible apps for this tablet or can someone post what model and such to put in?
A safer way is to use an app called market helper (http://codekiem.com/2013/02/13/market-helper/).
Instead of changing your build.prop fingerprint, this app provides a list of devices to choose from, then everytime your device communicates with google play, it changes the fingerprint in the message that gets sent to google. This means it won't break compatibility with ROM updates.
There aren't many devices available to choose from, but there are a few good ones that make nearly all apps available.
ShaunMTFreaktab Rom Developer
Regarding BRICKED Next8HD8G Tablets
FYI guys...
I've figured out why some of the Next8HD8G tablets are bricked. There are two different versions, with completely different hardware. They have overlapping manufacture dates by at least two months and may be for sale side by side. In fact I know someone who bought two of them at the same time, with the same month of manufacture and got one of each version. The ROMs are completely incompatible with each other.
I've been testing the two models for over a week now. Soon, I'll be able to post details concerning how to identify the two versions via the stock build.prop entries, along with compatible ROMs for the bricked models.
You will also be getting CWM recovery at the same time, and unbrick kits with premade Magic SD card images to revive the bricked tablets.
That's just nice, I may have to borrow my sister's tablet again so I can see the build.prop inside her. That way if it bricks on her, I can hopefully fix it. Thanks again for all the hard work. And seriously, I may end up not getting another Nextbook because of EFUN's/Yifang's practices.
Until then,
RosaFangNEXTBOOK NX700QC16G Rooted with updated firmware to allow 13GB App Space
Originally posted by RosaFang View PostThat's just nice, I may have to borrow my sister's tablet again so I can see the build.prop inside her. That way if it bricks on her, I can hopefully fix it. Thanks again for all the hard work. And seriously, I may end up not getting another Nextbook because of EFUN's/Yifang's practices.
Until then,
RosaFang
Originally posted by locuraconsigueusted View PostNot to sound like a bad character or anything
When someone is putting this much effort into helping you out with your problems you should be patient and thankful. You are being impatient and ungrateful. Please don't do that.
ShaunMT - Thank you so much for all of your effort. I, for one, am very appreciative and will politely and happily wait until you graciously might have the time to help us out. It is very philanthropic of you.
In thanks I offer you this dancing banana -
Yes, I did know how I sounded before I said it, but wanted to explain why I was asking when he would be done.
And I do appreciate his work...
Sent from my Event using TapatalkLast edited by locuraconsigueusted; 03 February 2014, 22:01.
Just Bricked an anxiously Awaiting ShaunMT's package
Appreciate your work. Thanx in advance!Originally posted by shaunmt View PostFYI guys...
ShaunMT
CWM Recovery Released for Next8HD8G-NXM8000ND_WM
CWM recovery has been released for the Next8HD8G-NXM8000ND_WM:
CWM-Recovery-with-UBIFS-Support-For-Amlogic-Nextbook-Tablets
Warning!
Do not confuse the Next8HD8G-NXM8000ND_WM with the Next8HD8G-NXM8000NBD_WMN
The NXM8000NBD_WMN models are the ones that bricked when they flashed files for the NXM8000ND_WM.
I'll release files for the NXM8000NBD_WMN models next.
Sweet!
You the man!
Originally posted by shaunmt View PostCWM recovery has been released for the Next8HD8G-NXM8000ND_WM:
Warning!
ShaunMT
Warning!
ShaunMT
Originally posted by locuraconsigueusted View PostHow can we tell the difference (especially if we are bricked)?
If you currently have a bricked Next8HD8G, you most likely flashed a NXM8000ND_WM ROM on a NXM8000NBD_WMN board, considering that I have not yet released any NXM8000NBD_WMN ROMs.
All of the current ROMs for the Next8HD8G are for NXM8000ND_WM boards.
I'll be releasing new stock ROMs for both boards within the next week or so, along with CWM and Unbrick Kits, depends on how long testing takes, considering I don't own one with a NXM8000NBD_WMN board.
The new ROMs will automatically back up your current bootloaders, build.prop, and dmesg output before installing, so as long as people do nandroid backups in CWM before installing, they'll have all the parts necessary to create a proper stock ROM and unbrick kit if they screw up and install the wrong ROM on a tablet that doesn't already have files available.
There are currently 3003 users online. 4 members and 2999 guests.
