Amlogic Next8HD8G (NX008HD8G) Modified Recovery - Stock Rom & Flashable Root
    Originally posted by cchomebrew View Post
    ShaunMT - first off, thanks much for your development efforts here. I purchased a NX008HD8G earlier this year and rooted with no probs. I purchased another last week and applied the same procedure - froze on bootup (woman with headphones). I attempted to restore the stock rom and it's now completely black. No reset, no color, nada. I then found Jiero's response above and it looks like I did the same thing he did.
    It is a nextbook NX008HD8G with serial YFG101309... manufactured Oct 2013 (bought from walmart). Hope this helps and thanks again for your work.
    Thanks for the info. It sounds like eFun changed something in the hardware on the Oct 2013 models. Unfortunately, I can't do anything about it until I receive a dump of the ROM from somebody.
    I will update the OP to note that these files don't seem to be compatible with that build date. Hopefully someone can root one with Cydia Impactor and dump the ROM for us.
    ShaunMT
    Freaktab Rom Developer
      Originally posted by locuraconsigueusted View Post
      Yes, will not boot at all, no recovery, no screen backlight, nothing whatsoever. Same whing as cchomebrew, with the exception of the S/N, which is YFG1113042017, build date 1113 ("MANUFACTURED NOVEMBER, 2013", the box says). Going to return to Walmart to get a new one. Thank you for your time and help. Attached are photos of the box, if that'll help for other people.
      [ATTACH=CONFIG]4475[/ATTACH][ATTACH=CONFIG]4474[/ATTACH]
      Try to get another one with a 1013 or 1113 serial. You can most likely root it with Cydia Impactor, then dump the ROM for everyone else with a bricked tablet.
      ShaunMT
        Ok
        I have a NX008HD8G. Baught at Walmart. Serial is YFG101310....
        I flashed the root. Rebooted, Got stuck on woman with headphones.. Flashed the stock, now stuck on pointing finger. (After a few swirls completely freezes).
        I wipe the cache twice before ROM flash, same thing. Tried over and over.
        Am i right that the ROM wouldn't install completely if custom recovery wasn't present?
        I am getting a complete intallation for stock rom, so i am safe to assume that your custom recovery is working on my tablet, correct?
          Originally posted by mcfly View Post
          Ok
          You are correct. Without the custom recovery, the signature verification fails and the install aborts before it even starts to write anything to your device.
          It sounds like something changed in the hardware in October. We need an October or November ROM dump.
          ShaunMT
            HOPING
            ShaunMT
            REALLY HOPEFULLY SOON, I BRICKED MY SONS TAB. I FEEL LIKE POOP, I LOST MY RECEIPT
              NOV. ROM DUMP
              Update: This ROM Dump is for Model NX007HD8G, not NX008HD8G.
              Here's the post:
              FYI everyone:
              I will start an upload of the Nov. build ROM dump shortly. I'll send a note when it is completed with download links.
              Model: NX007HD8G
              Serial: 11130...
              MFG: Nov. 2013
              OS: 20131010 v4.1.1
              Store: Newegg
                Originally posted by MoeFoh View Post
                FYI everyone:
                Serial: 11130...
                MFG: Nov. 2013
                OS: 20131010 v4.1.1
                Store: Newegg
                MoeFoh
                You Rock! I assume you rooted with Cydia Impactor? Do you need instructions for dumping the ROM?
                ShaunMT
                  ShaunMT
                  YES, no problems, using windows version on WinXP computer.
                  Followed your dump instructions from a previous post.
                  Looks like the upload will take about 2 hours. It will be 5 file download in 7z multi-part format. Download will be from my Dropbox account.
                    Sounds perfect!
                    ShaunMT
                      Ooops...
                      My bad. The ROM dump will be for model NX007HD8G. Sorry for my confusion.
                        Well... upload it anyway... I don't think I have one that new for that model either!
                        ShaunMT
                          I did the same thing. I got this tablet for Christmas and I tried to root it with the zip file. Now it won't boot past the woman with headphones. Unfortunately I downloaded it from a different site and did not get to see the warning messag.... And I am afraid to try anything else because it seems to get worse for other people lol
                            Internal Storage Full
                            After rooting my tablet, all boots up fine, but settings->storage shows that my internal storage is full. Is this a permissions problem? Tips on how to fix?
                            thanks.
                              thanks.
                              SD card mounting issues (as well as wifi issues) are often caused by corrupted cache or dalvik cache. Wipe cache and data (data contains the dalvik cache). You may have to wipe more than once before the problem resolves itself.
                              ShaunMT
                                ShaunMT;
                                Nice to meet you (and all else on this board)
                                In my exploits to root and rom android devices I've been brought to unleashedprepaids.com androidarea51, and many other places.
                                There hasn't been an android device I haven't been able to *find* a root/rom for yet, until now.
                                I see you've done some fine work getting the Amlogic 8hd8g rooted, but only up till the September builds.
                                Apparently they changed something in the October and on builds.
                                I understand that you need a rom-dump from one of those devices. I'm sitting here with 1113 serial amlogic that I haven't even had for 5 hours yet. I want to root it and rom it.
                                Help me help you, yes? Give me a link to a step-by-step to get you your rom-dump and I'll have it up here for you in no time.
                                Looking forward to being of assistance.
