T-R42/ MK888B/ CS918 with bluetooth
Hello! I bought T-R42 yesterday and a have a few questions:
1)How can i turn off this device? If you press the button on the remote or off in the system, the console go to sleep.
2)How can i configure pppoe connection? The android box has an RJ45 connector, but I can't connect to the Internet, because I have a pppoe connection. Please help, I have no wi fi at home
P.S.: Sorry for my English, I write with the help of a translator.Last edited by nusferatu; 10-04-2013, 00:52.
Originally posted by nusferatu View PostHello! I bought T-R42 yesterday and a have a few questions:
2) You need to download this app to use wifi through PPPOE, this app will provide user login info which needed for PPPOE connection. https://play.google.com/store/apps/d...nddu.wifipppoe
Originally posted by buhohitr View Post1) To turn off the device you need to root it and download an app called "Rebooter" from the market to turn it off or use the soft power button came with the device.
Originally posted by nusferatu View PostBut I have no wifi router, I have only one cable with RJ45 connector. How can i configure pppoe connection directly, because the T-R42 has an RJ45 connector?
Originally posted by buhohitr View PostThat's correct, in settings, turn on Ethernet (RJ45) and turn off wifi, they both turn on by default. Then install the apps to config pppoe. You may need to borrow wifi from friends to download the software on to your device (cause you don't have internet yet).
I'm expecting delivery of my machine in the next couple of days and it's the on without Bluetooth, but it set me wondering.
If the bluetooth model that is built in to the newer models is identified and then happens to be available in some USB form, would plugging one in likely enable it to work without any requirement to build anything into a ROM?
I'm making an assumption that if a ROM has the appropriate drivers, then that would be enough to enable it from an external source.
Or is it just wishful thinking on my part?R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
RK3288 Devices
- Overview BOX (LINK !)
Originally posted by bluesmanuk View PostI'm expecting delivery of my machine in the next couple of days and it's the on without Bluetooth, but it set me wondering.
Original firmware for MK888B T-R42
I have T-R42 mk888b with bluetooth
I installed the firmware K-R42 Hybrid Firmware v2.0.4 but after starting ETH, WiFi and Bluetooth not working
ETH appears to be on but will not take IP from a DHCP. static IP not help
someone have original firmware for this device T-R42?Last edited by belickam; 10-05-2013, 12:56.
Ok, guys, K-R42 got the new stock firmware, in our effort, factory finally release the new firmware, which fix the netflix problem, now Netflix can work on K-R42 tv box. Here is the firmware download link: http://www.mediafire.com/download/k9qan8v7v21il21/RK3188_BOX_Kingnoval_K-R42-1_NEUTRAL_8188EU_20130702_B.rar password: geekbuying.com Here is the instruction for how to install the stock firmware: https://blog.geekbuying.com/index.php/2013/07/03/how-to-update-firmware-on-k-r42-quad-core-tv-box/#.UdPNkm37pns Here is […]R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
i don't make backup orig firmware
There are currently 2425 users online. 8 members and 2417 guests.
