T-R42/ MK888B/ CS918 with bluetooth
yes i downloaded it using IDM but can upload it as im in work now.Everything is possible if we work together!
Have just tested the latest rom, Wifi, BT and Ethernet do not work. Wifi and bluetooth will simply not turn on (sit there trying to turn on and then return to being off). Ethernet is on by default, but when connected to the network does not get IP address or any data. Toggling ethernet on and off does not fix this.
Another thing I have also noticed, when coming out of standby the machine becomes very laggy / stuttery. A reboot fixes this, till the next standby.
Stock IR remote is working fine.
thanks bryce007 and bil-ns
so i will use older rom provided by eric from geekbuying.Everything is possible if we work together!
i found it on some china website and tought that it may be compatible with t-r42
it was newer than the one i have so i wanted some one to try so i can know if its working or
not as i dont have t-r42Everything is possible if we work together!
Originally posted by lewy20041 View Posti found it on some china website and tought that it may be compatible with t-r42
Downloading firmware
rom delayed until tomorow.
sory for this, want make it today.Everything is possible if we work together!
If you could would you please do a quick how-to for the installation? Is CVM needed? If yes, can we use the k-r42 file from the CVM thread?
netflix running with your fimware?
im am currently running rooted stock build 20130927 and have the typical netflix problem with hanging video from time to time.
do you expect netflix to work properly with your firmware?
how to remotely control my cs918 from pc?
Hi all,
I have a cs918 connected at home. i would like a way to connect to it from my pc at work to fully operate it (start torrent, send mail, up/download files...) does anyone know how?
the apps i tryed:
teamviewer - work only on samsung
mobizen - doesnt work on lan connection, only wifi and usb
airdroid - cant see the cs918 screen anly the folders and some data
any suggestions?
Hello.
Hello lewy20041.
Pozwól, że napisze po naszemu bez tłumaczenia - tu masz wersje pod Mini Pc Jesurun z bluetooth:
https://hotfile.com/dl/252360916/730...ZYSTY.rar.html
Proszę podziałaj, by wszystko poprawić z firmware.
Dziękuję.
Teamviewer for rooted android
Hi lewy20041.
I read that teamviewer can run on rooted android.
this is the link that talks about that http://www.androidbeat.com/2013/05/t...ed-custom-rom/
it says that teamviewer quicksupport can run on for devices running AOSP (Stock Android) or any AOSP based custom ROMs like CM10.1/AOKP/Paranoid Android withroot access.
Is it posible that te firmware you make will support teamviewer quicksupport?
thank you and good luck,
Boris.
There are currently 3515 users online. 3 members and 3512 guests.
