I have had enough of this tab. I have not been using it for weeks, and now that I powered it on, all apps started with force close. MX player reported corrupt storage. I am going to get one last bit of satisfaction by smashing this piece of shit on the floor and then I will go for iPad Air.
Pipo M6 4.2.2 RileyROM 1.8 [MAX not PRO]
enough is enough.
Originally posted by rrileypm View PostWhile my 1.3a firmware is nice, there are still some problems with freezes and wifi not turning on automatically at boot...so I'm hoping for a fix to those problems. Meantime, Finless and I are exploring some remedies to the problems we can try. That's still in progress, though. I'll tell everyone later what we've come up with.
The tablet is now working an absolute treat for me, this ROM has made everything perfect again (apart from losing Deep Sleep for my 3g functionality, but that will come with time I guess)
My WiFi starts perfectly at startup, and I have not experienced a single freeze since installing 1.8a.
Thanks! (again)
PiPo M6 Max 3G RileyROM 1.9
Hyundai T7s SPCleanROM 4.04
Asus Transformer Prime ChaOS 4.3.1
Samsung SGSII SlimBean 4.3 Build 2.2
Sorry...wrong thread...I was talking about my M6 Pro. I try not to do that.Randy
While you are here, I'd like to get your opinion on what the 'best' ROM/Kernel combo for the M6 would be?
I've read through almost all your 1.1 - 1.8 threads but it's always hard to follow when I'm reading old threads. I've read about the mixed 1.5/1.6 ROM/Kernel (or Kernel/ROM?) but I am super happy with this 1.8a version too.
Also, are the tweaked Kernel's by balrog still usable, or have they been implemented in to this ROM?
I'm not completely sure, first hand...because I don't have an M6 tablet to test.
Maybe some other users can chime in on the best combination for the moment.Randy
I've decided not to try keeping up with the kernels to include in my releases. Mainly because whenever I release a new ROM, nobody has touched the newest kernel unless they were able to extract it from the firmware before I do. So...mostly the kernel guys rely on me to give them kernels to patch.
Usually the OC kernels come a bit later after a ROM release.Randy
Originally posted by zdr View PostI have had enough of this tab. I have not been using it for weeks, and now that I powered it on, all apps started with force close. MX player reported corrupt storage. I am going to get one last bit of satisfaction by smashing this piece of shit on the floor and then I will go for iPad Air.
Just want to jump in and say that after working quite well for a while, I tried installing some games through the Humble Bundle app and they didn't work - they would just FC. I tried to reboot the tablet and it would not load past the RileyRom start splash (before the boot splash screen). Rather than reflash 1.8a I'll give 1.9 a shot.
Re: Pipo M6 4.2.2 RileyROM 1.8 [MAX not PRO]
Originally posted by krucifix85 View PostJust want to jump in and say that after working quite well for a while, I tried installing some games through the Humble Bundle app and they didn't work - they would just FC. I tried to reboot the tablet and it would not load past the RileyRom start splash (before the boot splash screen). Rather than reflash 1.8a I'll give 1.9 a shot.
Sent from my M6 using Tapatalk
Originally posted by guest2013 View PostWith that in mind got the fix. Waited overnight to power DOWN the battery. Meanwhile I installed the correct drivers manually so that when the device was powered up it would show as rockusb in device manager and not Android as what was happening before. I had the pipo flash tool ready with official firmware ready. Plugged in power on tablet, usb connected to pc. Pressed volume + and power and device manager picked up rockusb, flash tool showed device was connected and I hit upgrade and bingo.
Now which riley Rom is deemed to be the most stable?
Sent from my HTC One X using Tapatalk
Originally posted by levicius View PostIs there any possibility that after this ROM the device won't charge ? Because its happening with mine .
Originally posted by Relles View PostI had exactly the same problem with my Pipo m6, was the same with any rom I put on it though. If you leave it long enough it will go up, I think what is happening is it gets to 100%,And only then will the battery indicator start, You'll notice it goes up very quickly, As it is actually already at 100% so the indicator increases as quickly as it can. You just have to leave it, what helped me is downloading an app that alerts you when the battery is fully charged.
Enviado de meu Nexus 7 usando Tapatalk
There are currently 3806 users online. 1 members and 3805 guests.
