Pipo M6 4.2.2 RileyROM 1.8 [MAX not PRO]
Originally posted by levicius View Post
Re: Pipo M6 4.2.2 RileyROM 1.8 [MAX not PRO]
Originally posted by Relles View PostAhh no, mine didnt do that, that is a totally different problem. Perhaps try rebooting to CWM and wipe the cache and Dalvic cache's I would also calibrate the battery, you can download an app on the market for free. Its good idea to do this after installing any new rom. If that dosnt work then more then likely you have a faulty charger port.
Enviado de meu Nexus 7 usando Tapatalk
Originally posted by rrileypm View PostThis ROM is based on the Pipo firmware test release dated 9/13/2013.
This is for the original Pipo Max M6 tablet...not for the M6 Pro...these ROM's are not interchangeable, so be certain of which model you have before flashing.
Also, there is only one version for either 3G or WIFI models. It works for both.
v1.8 Features:
Full Root with SuperSU
Debloat
Google Play Store fixes, to all for more compatible apps
Reduced System.img file size with ext4 file system
2, 4, 6 or 8gb user app space parameter files
Your choice of stock recovery or CWM (Stock Recovery is the default)
Multi-user support (I finally got this to work correctly) You will see a new option called Users in settings.
Some Internet/Wifi tweaks to improve speed and streaming
Some video performance adjustments
A few general performance enhancements
The Petrus Reboot app
Disabled OTA updates
Boot animation from Tattman65
tun.ko, cifs.ko installed
UPDATE: v1.8a is now available. This version is based on the same firmware as the 1.8. The difference is that after testing many of the tweaks in 1.8, I've made a few changes. Some reported the VPN drivers I added weren't working...so I added ones that work. Plus, I expanded the size of the file system to allow users to change things without getting errors. v1.8 works, but v1.8a is just a better ROM.
Download:
RileyROM v1.8
RileyROM v1.8a
If this ROM makes a difference for you, please consider a donation to support future RileyROM's here at Freaktab.com Donate!!!
kindly help
There are currently 1655 users online. 3 members and 1652 guests.
