Pipo M6 4.2.2 RileyROM 1.8 [MAX not PRO]
    There is a ROM hacking and development section.
    If anyone wants to learn, I'm willing to help.
    Randy
    Randy
      Re: Pipo M6 4.2.2 RileyROM 1.8 [MAX not PRO]
      Thanks for the info! I will be looking around. :-)
      Here is the proof pic of deep sleep over night:
        how to enter maskrom mode
        After flashing 1.8a I stuck on boot loop, since I messed up the ESC and volume rocker can't enter flash mode manually. For those coming across the same problem just open your tab and locate and connect the pin 7 & 8 on nandflash nearer to the battery using a needle or something (you'll find a dot mark on the chip start counting from that and the pin nearest to thats is pin no 1) connect the tablet with pc and open flashtool and power on while connecting pin 7&8..... walla...Enter maskrom mode ....... erase idb and flash manually using the 2nd tab on flashtool......
          Originally posted by Balrog View Post
          You just have to name a ROM with this modifications "Wifi only" and everything is alright.
          Wifi works as estimated.
          btw: where I can find the threads you mentioned?
          I don't think it's a good idea.
          Rename the lib file is enough (and pretty simple) to enable deep sleep.
          No I'm going to try if making some modifications to the build.prop could do the trick of deep sleep without losing the 3G funtionality at all.
          At the same time I have contacted Anna Ye (Pipo customer care), giving her all the information relevant to the libraries that are "locking" the CPU.
            just speculating
            I've got 3g version and when flash with this rom after copying a large data or restarting it always stuck on on bootloop. ... while some reported that this rom works fine on their devices.... maybe this particular rom is compatible with wifi version only.... ... as I had mentioned before.... just speculating...
              thanks for this rom
              hello, thanks for this nice rom. it works nice on my pipo m6 3g better then stock rom with freeze. yesterday i restart my tablet and then comes this picture and not more. why? the tablet dont work. what can i do? please help me.
                [ATTACH=CONFIG]3931[/ATTACH]
                Seems to be an issue with this rom (or the base rom its based on) after copying files over to the tablet... mine runs fine as long as i don't copy large amounts of data.. as soon as i do its reflash time..!
                Steve
                  I do not understand. is this a general problem? should I now again the version 1.8a flash over it? but does not because the tablet is not recognized and therefore not drive in the flash mode. what can I do? the tablet is now useless? it went so well :-(
                    I've heard reports of this happening in early M6 releases. I'm not sure it has been completely fixed in later firmware releases...yes, it is a general problem.
                    A workaround would be to format your external SD as NTFS. Then copy your data over to it.
                    Randy
                    Randy
                      [HELP]
                      just finish flashing the rom working fine and smooth..
                      then i install some games. put all the data & obb files. then then unit hang try to reset the unit then bootloop appear i cannot access anymore. then i try to recover restore factory settings via CWM. restore factory finish then i restart my unit. still the same stock at riley rom logo. then i try to flash via rom flash tool. erase NAND (IDB)- flash ROM. flash finish done ok.
                      (i did not click *reboot into flash mode) i got a message (device can not do switch, because of no drive).
                      OR
                      is that important? then 2nd attempt i transfer games data and obb files then the unit turn off try to on the riley rom logo stock again...
                      i try to flash the official pipo firmware using batch tool v1.7
                      connected device is green ready to flash then i get this error. download firmware fail at 38%.
                      help me. is this hardware problem or software? using stock rom before i did not get any bootloop problems.... pls help...
                        Are you using the USB cable that came with the tablet? It sounds like a bad data connection. Try a different cable and use a different pc port (USB 2.0 only).
                        Randy
                        Randy
                          Randy
                          I use so no external SD, so only the internal memory. I have no idea how I should change because the format.
                          Now I have flashed the firmware again (riley rome 1.8a) and it runs. after 2 restarts I'm back in the screen above.
                          in which the rom is running the pipo m6 best? or should I use the original firmware again?...
                          I had the same problem. connect the tablet via usb to pc open the alternative batch tool and then press the reset button on the tablet. the tool would recognize it and you can flash again, worked for me fine
                            Randy
                            yes im using the original pipo data cable. i also try my sony ixperia data cable. still the same.
                            but flashing your firmware sir is done ok. i remember i had the same problem with the pipo u1 pro. the tech guy said the CPU has a problem then he put the mother board in the machine computer for CPU i don't know what machine is that. then try to flash the unit again works 100% finish.
                            hope not hardware or semi brick.. is semi brick, you cannot play with your tablet also?
                            or im using rooted firmware need to unroot 1st so i can flash the official pipo firmware?
                            BTW: is (reboot to flash mode) is really important or i can skeep that? because i can access the (erase NAND flash) and (flash Rom)
                            i think this is the machine what im talking about to fix the CPU
                            here my m6 now
                            if im going to transfer some games data the unit will be bootloop. i just finish flashing this for 3rd time via rileyrom about 5mins ago.
                              i got a green icon box at 1st. then click the restore 1 to 37% ok by 38% download firmware fail...
                                i use the batchtool only to connect, 1 step when is green then open the romflashtool und erease nand ->flash, not switch, it works
