Pipo M6 4.2.2 RileyROM 1.8 [MAX not PRO]
You can find it on www.pipo.cnif you appreciate my efforts this is the link for any donation:
Here is the link to the stock ROM.
Sorry you are having problems. While you are flashing, you might try my 1.7 version and see if it runs OK for you.
Randy
http://www.pipo.cn/En/index.php?m=Pr...&type=2&id=290
The correct link for the M6 non Pro is the following:
Sorry...I didn't pay attention to which thread I was on. OOOOOPS!!!!!Randy
Originally posted by zdr View PostMine just started crashing and eventually failed again - stuck at riley boot logo. I need to go back to stock, because something is really messed up here. I barely used it in the meantime.
Does anyone have link to stock rom?
STUCK!!!
HELPPPPPP I loaded rom 1.8a in fine loaded some software then decided to restart tablet with non hd screen to make tablet faster. now tablet stuck on rileyrom screen. tried reset and nothing happens. tried to connect to pc the pc has error ardriod device message. tablet wont do anything just stuck on rileyrom screeen for the last 30 mins. HELP!!!!!!!
Joe
You will need to reflash the ROM.
First press reset with a paperclip to turn off the tablet. Now use the steps for the M6 to get the tablet into manual flash mode:
Randy
Nope...just experienced.
You can't do anything to a Rockchip device that hasn't already been done (by me...hahahaha).Randy
Just to keep the balance here.. after upgrading from 1.4 to 1.8a and installing crossbreeder I can actually say that without a doubt (everything is crossed) that the tablet is fast and the random freezes have stopped. Battery life is also incredible. as of last night I was on 54% after 5 days being 'on' with wifi having been connected for all of that time (115 hours) and the screen only having been used for about 1 hour. Keep awakes were on 31 hours!
So its not all doom and gloom and RRoms do work well! There is either some hardware issue or there is something wrong with the flashing.. Are you guys messing with the parameters? I'm pretty sure i used the 4gb parameter file..
Something must explain it..
Steve
Originally posted by hoilai View PostFirst , you have to go to alternate_reboot_to_flash_tool, then rkbatch tool.exe, press switch mode, then the icon will turn from pink to green, just leave it here. Then open another exe, ROM_Flash_Tool_137.exe, press erase IDB, wait for reboot, and you can press flash once it was finished.
However, after I flashed the rom(1.8a) and installed a few apps, the tablet go freeze. I reset my tablet and it stuck on the Riley logo. Ok, then I fre-flash the rom again, it work again. But after I installed a few apps, it freeze again and I reset my tablet again, and it again stuck on the Riley logo.
Any help on this? thanks!
Does the Bootloop have something to do with the parameter......!!!!!
I've change the parameter from 2gb to 4 gb by changing the parameter4.txt to parameter (also change parameter to parameter2.txt) I've got no issue when using the default parameter file (2gb)..(though I've tried this method only once) but when I used the parameter4.txt (instead of the default parameter) it always stuck on bootloop when reseted. Riley Is there something wrong with the 4gb parameter?
Originally posted by elephraim View PostI've change the parameter from 2gb to 4 gb by changing the parameter4.txt to parameter (also change parameter to parameter2.txt) I've got no issue when using the default parameter file (2gb)..(though I've tried this method only once) but when I used the parameter4.txt (instead of the default parameter) it always stuck on bootloop when reseted. Riley Is there something wrong with the 4gb parameter?
There are currently 2380 users online. 1 members and 2379 guests.
