Pipo M6 4.2.2 RileyROM 1.8 [MAX not PRO]
Yes, that's very odd. It has to be Window drivers.Randy
Re: Pipo M6 4.2.2 RileyROM 1.8 [MAX not PRO]
Don't let the battery run all the way down to zero. It may not take a charge again...ever.
Sent from my M9pro using Tapatalk 2Randy
Originally posted by guest2013 View PostThanks for giving me hope. I will uninstall drivers and install again when tablet has died and charge up again.
I will let you know how I get on.
Ok now when connecting the tablet I get Android under other devices show up in device manager. I click on update driver. I select to choose drivers myself. But when i select the right path. I'm running 32bit Win7. (86x folder) it says no drivers cannot be found. If I select devices and "have disk" I can select the appropriate device 'rockusb' and it is when the software is installed come back with device cannot start.
Are there any other/older version of the drivers that try?
Yes that's the last official release. This ROM is based on a test firmware not yet published.
Originally posted by rrileypm View PostYes that's the last official release. This ROM is based on a test firmware not yet published.
another question, is it possible to flash the bootanimation back to stock but stay with the custom rom? cheers!
Changing the bootanimation isn't difficult...there are apps available...or simply use a rooted explorer tool and browse to system/media. The replacement needs 755 permissions.
Originally posted by Relles View PostYeah thats the problem he is having, he cannot use the reset button to turn the tablet off, and when he tries to install the drivers he just get an error 10 message in windows, Im convinced this is becasue the drivers have not installed properly. I mean if the tablet can boot to stock recovery then it should def be detected properly by windows when the rockchip drivers are installed.
Sent from my HTC One X using Tapatalk
Look in build.prop. you might be able to change it back to rockusb.
Originally posted by rrileypm View PostLook in build.prop. you might be able to change it back to rockusb.
Sorry...my bad...you need the ROM to be rooted to do it.
Originally posted by guest2013 View PostI think you are right about the drivers. When I connect the tablet to the pc it shows up as Android in Unknown devices. I think the message from the tablet to the pc is not recognizing the device as rockusb, therefore not installi
Now which riley Rom is deemed to be the most stable?
Originally posted by rrileypm View PostChanging the bootanimation isn't difficult...there are apps available...or simply use a rooted explorer tool and browse to system/media. The replacement needs 755 permissions.
inst it possible to skip those somehow?
There are currently 1983 users online. 0 members and 1983 guests.
