Pipo M7 Pro RileyROM 1.7
BTW, I got an Antutu score with this new combination of 19562 last night.Randy
Randy,
You'll find it here http://ge.tt/6r0fkyv/v/0?c in few minutes
BTW, I have created baidu account and downloaded kind of software for their cloud service. The matter is just to find where are the buttons OK Cancel etc. After that no problems with downloads, max 15 minutes for Pipo ROM of 700+ MB
Also, found couple of useful apps on Play Market:
1. Magnet unlocker - with this one my M7 goes to sleep with cover closed, using magnetic sensor. Just real smart cover
2. Custom Auto Brightness - little bit of tuning and light sensor responce improved significantly.Last edited by fazerg; 10-22-2013, 18:14.
I installed the baidu app. But, like you say, I couldn't figure out which buttons to push. Plus, it also installed a bunch of Chinese crapware on my PC.
Thanks for the link, I'll give it a try tonight after work.Randy
For me it did installed only program for cloud services, without it download is same slow. Unfortunately, I can't remember what I did click, it was far not yesterday. And there is no way to translite it as I do with chinese webpages using Google. But once it's running I do just right click on desired file stored to cloud and select first option in dropdown menu. Download starts and goes pretty fast.
Sv: Pipo M7 Pro RileyROM 1.7
Originally posted by rrileypm View PostOOPS...sorry, I meant this version...I haven't done a 1.8 for this one yet...silly me.
Just use the kernel from this ROM...1.7 with the M8HD ROM.
Meantime, if anyone can send me a link to the new firmware update, I'll start work on 1.8 for the M7 Pro. I have a feeling it's going to be a variation of that one for the M8HD.
Here is the M8HD ROM:
http://www.freak-tab.de/rrileypm/Pip...leyROM_1.0.zip
Skickat från min M7pro via Tapatalk 2
Hmmm, that might be a problem for GPS users...hahaha!!!!!
We'll see how this new firmware works out. I'm downloading it now.Randy
Netflix on RileyROM 1.7a?
I recently put RileyROM 1.7a on my Pipo M7pro. I have not been able to use Netflix since. The app loads. I can select a movie. Then the spinner just spins and spins and never shows the movie. I have re-installed, cleared netlflix cache/data, etc.
Is this a known issue with the ROM?
I think Netflix was working on mine with 1.7a.
I know for a fact that Netflix works with the M8HD ROM with the v1.7a kernel. I tested it last night after I flashed.
I'm still downloading the new firmware...maybe tomorrow I'll have a new ROM. I want to test things out before I release it.Randy
Originally posted by antoid View PostI recently put RileyROM 1.7a on my Pipo M7pro. I have not been able to use Netflix since. The app loads. I can select a movie. Then the spinner just spins and spins and never shows the movie. I have re-installed, cleared netlflix cache/data, etc.
ef98dpa, what kind of with 20 magnets and suitable for Pipo M7? For me this one is working perfectly well. The only thing service stopped after I did Titatnium back-up before flashing update#6 last night. But just restarted it again and all works.
Not sure about M8HD but others M8 do not have GPS even with 3G version. Therefore, no GPS - no support in ROM, right?
BTW, I've managed to get 19856 AnTuTu on this update #6. However, get once crashed everything as well, first WiFi than entire system while was trying to update some Google apps from marketLast edited by fazerg; 10-23-2013, 04:36.
Randy
There are currently 2451 users online. 6 members and 2445 guests.
