Minix Neo X7 - Finless 1.8 ROM
Originally posted by roughie3 View PostBob, I;m getting lines of green flashing squares with this rom and only in certain menus. Unfortunately, it's also in XBMC, which is my main use for the x7. Any ideas? I've factory reset and changed HDMI cable etc so def hardware/rom related.
Originally posted by Hjhoekie View PostSame issue here, green horizontal flickering lines, but not all the time. Also in settings menu.
all i can say is that many other people also have the same issue although they are running xbmc on windows.
okokok,its windows,BUT every issue on windows has been solved.
the peole had to disable hardwareacceleration
so my thought is that it maybe has to do with hardwareacceleration ??
in windows the users had to disable dxva2
see here :
this is not a solution but maybe a hint to the right way
maybe try to disable ALL hardwareacceleration and see if the green squares are gone.
tell us if its working ok?
we have to solve that ^^
Originally posted by dermuggi View Posti can see that this is an issue on some minix so ive tried to find a soultion.
see here :
Will try for xbmc, though the problem is that it's in the standard menu before xbmc as wellWill try anyway
Originally posted by roughie3 View PostThanks very much for trying to help again dermuggi
to ALL people here with this special problem,pls post your problems and all the stuff in this posting -->>
because this posting is for finless rom only ^^
and i dont want to spam into his posting hahaha.
and i think it will last a little bit to solve this problem and i dont want to have about 30 postings ONLY about green squares inside finless posting ;D
so-->> pls got to the right topic :
i also have found some new conclusions,but u have to look inside the right secrion ok?
thx
You start your lines with 'today is a special day, 1.9 could be released today'.
it sounds like you heared some info there is a 1.9 coming soon.
thereby you brag another time with some lines about how
curious you are what it will look like and how it will work..
As if you know 1.9 is already made and almost will be released...
but no problem.
the same as you I hope bob will make a new finless rom 1.9 or even a 2.0
i hope he will use 4.4.2 as base, this will make the x7 amazingly fast.
i run now the nitro v3 rom it is 4.4.2 and the box is amazing fast.
even without overlock it makes 220+ in linpack.
in 4.2.2 it was around 160.
Originally posted by Hjhoekie View PostI don't, you need to read better. The word "could" was used.....
Originally posted by Hjhoekie View PostToday is a special day, 1.9 could be released today!
I'm very curious ,what will it look and work like?
Waiting......
Originally posted by Killerdude View PostHoe weet weet jij dat zo zeker?
Apparently you didn't read this...!?
http://www.freaktab.com/showthread.php?9388-Will-there-be-Finless-1-9-Yes-there-will-be-)/page3Last edited by Hjhoekie; 02 June 2014, 08:26.
[Quote = Misteral; 168921] Hola a todos, Sólo quería decir un gran agradecimiento por esta ROM y los núcleos incluidos. Creo que esta es ROM número 5 o 6 ahora para mi pequeña Minix. Recordé este porque quería los núcleos overclockeado - acaba de conseguir un nuevo 4K 3d tv y el Minix estaba luchando un poco. Bueno, ¿qué puedo decir? Fluido,-de hinchado, rápido, agudo resolución - simplemente genial en todo. Algunas películas 1080p sufren un poco de tartamudeo (Vengadores, en particular), pero esas películas son mi prueba de fuego. Ellos siempre tartamudean y aquí es lo menos que he visto (también, tengo que comprobar si esta es la reproducción o la velocidad de la red - que podría ser la red). Aparte de las películas de problemas, todo lo demás funciona muy bien. 720p se ve hermosa, películas 1080p (excepto 'esas' otras) funcionan muy bien. Vi Wreck It Ralph anoche en 3D, 1080p y fue impecable. Muchas gracias por todo el trabajo que haces en tus ROMs, recomiendo encarecidamente este hotel para aquellos propietarios X7 que quieren exprimir el máximo rendimiento de sus máquinas. ( Todos mis videos se reproducen a través de la red de mi PC, usando MX Player a través de Plex) [/ quote]
misteral hello,
I have the 1.8 rom finless the neo minix x7 and I 3d visualization problems. The problem I have is that it does not block the image fine when I put a 3d movie goes a bit distorted and that movie to another device (raspberry) works well. I've tried several 3D movies it goes just as bad but not 1080p 3d movies work well. I've seen you with minix x7 and finless 1.8 will work well the 3d movies that have cunfigurado? from the cores need to install it?
thank you very much,
There are currently 1638 users online. 0 members and 1638 guests.
