Minix Neo X7 - Finless 1.8 ROM
    No SPDIF passthru with Air mouse connected
    I just received my air mouse A2
    Firstly sound output defaults to air mouse, already noted in the thread
    but worst of all the SPDIF passthru option is not showing
    So no way to get the full sound for DTS
    Any ideas?
    Running Finless 1.8 with OC kernal
    OOPS
    My mistake, I did not scroll far enough
    Found it lower on the screen
      internal NAND gets deleted /unmounted
      I use Finless Bob 1.8. Before that i used Quickshot v2. Both are great. I use Beyond XBMC and have used it on both.
      something happened twice during january.
      two times my internal NAND seemed to just disapear and XBMC got .. reset to a new install so to speak.
      I have to mount it again and with the result that i have to format it = zero data.
      anyone else experienced this ? i have a slight overclocked 720 ddr and use no frills to go 1.ghz - 1.6 ghz
      sometimes i experience a bit of lag in the xbmc interface - and feels like the android launcher as well.
      i dont have many apps, i mainly use the x7 for xbxmc and browsing.
      Standard remote, and a 2.4 ghz mouse.
      Can it be the OC that corrupt something sometimes or who can gimme some input on this weird matter?
      ps. thank god for backups - i do have 1000+ movies so....
        I don't know if this is relevant at all but if I unplug any of my mice/airmice dongles from the machine when it is on then my nand gets unmounted. I have to go into settings and remount it before I can continue. I don't know if it does it with all usb devices and I am not on this rom but I thought I would mention it.
        To Infinity and Beyond.... XBMC
          flumpster what rom are you on currently?
          and 2nd, unfortunately i dont even remove any devices from the unit when it happens. it just happens. mainly during browsing a lot of thumbnails in live streams.
          its just plain weird. my X5 dont do it. it is on Finless bob 1.3 ROM.
          im not sure it has anything to do with ROM type.. perhaps it is a hardware defect even ?
            The way you described it last time was as if your nand was becoming corrupted. You mentioned that not only your xbmc settings went missing but you had a load of blank icons in apps drawer etc.
            I am not even using the minix as my daily driver. I use the K-R42 with wassers older rom. 1.2.3 I think.
            I will be switching over to the new UT2 32 gig in the next day or two tho.
              I've been using this for a week or 2 and its undeniably a great ROM as to be expected from Bob. I am using the 720p - 1800/600/720 kernel toned down to 1008-1704 (I think) using no frills and get Antutu scores of 20300 which is great, but for the last week I've been having massive problems with lag despite antutu scores. Most apps freeze before they display properly or lock up and I have to close and reopen, despite the speed tests and good video playback on xbmc. Any ideas what's causing this. Also what would you recommend out of no frills and pimp my ROM? Pimp my ROM has a lot of additional tweaks but no frills seems to run better on boot. I am wondering if having the two programs installed is causing the lag or confusion although this is just a guess
              Sent from my GT-I9505 using Tapatalk
                installed finless 1.8
                install was okay.rebooted and let it do its thing for 5-10 minutes.once navigating through settings I noticed stuttering [flicker] every few seconds.then went to install xbmc for minix but got a message this software is for minix.i downloaded and installed Frodo and then went ok.navigating through xbmc was super fast,much faster than with the standard fw installed.when I played a music video clip there was constant flickering and the clip would continually stop and start and the same when watching a movie.the finless install was very buggy. sorry for my 1st post being so negative but this is what I encountered.if there was a fix,i would definitely try it again.
                w
                h
                n
                f
                I
                n
                s
                h
                e
                d
                  link failed
                  Hi every one
                  i found the download link is broken
                  thx man
                    Verstuurd vanaf mijn HTC One met Tapatalk
                      Download status
                      NVidia Shield TV 2015 16 GB || Stock
                      NVidia Shield TV 2017 16 GB || Stock
                      Buy me a beer?
                        Mount SD as internal storage
                        Originally posted by smokie171 View Post
                        Finless 1.8 is a rooted rom. It does not need rooting, already done. Does it have strasform patch on rom ? If not, you need to copy and paste with es file explorer or root explorer the patch. Good Luck Kevin
                        That did the job done thx.
                        Now I have one more question, i have SD Sandisk ultra 32gb. I would like to use it as internal storrage. I read about that there should be changed VOLD.FSTAB file. Is it safe to do it with this ROM, and can anybody tell me what has to be chainged in the file and how should the SD card be formated.
                        THX
                          Compile with Marvin
                          Can you please tell me the marvin compile config like ddr720 gpu600
                            Could someone with Finless ROM installed please test streaming video in the following apps?
                            -NFL
                            -AFL (may be Australia only)
                            -Sochi 2014 on Ten (may be Australia only)
                            Trying to play video in all of these apps on Quickshot makes the system crash. I just want to see if it applies to all X7 ROMs.
                              Originally posted by lachyzee View Post
                              -NFL
                              Not the best idea to spam the same question around everyones thread. Why didn't you just make your own post instead of doing that?
                                @finless
                                reading the characteristics of Andorid 4.4 Kitkat I found this:
                                Resolution switching through adaptive playback
                                Android 4.4 brings formal support for adaptive playback into the Android media framework. Adaptive playback is an optional feature of video decoders for MPEG-DASH and other formats that enables seamless change in resolution during playback. The client can start to feed the decoder input video frames of a new resolution and the resolution of the output buffers change automatically, and without a significant gap.Resolution switching in Android 4.4 lets media apps offer a significantly better streaming video experience. Apps can check for adaptive playback support at runtime using existing APIs and implement resolution-switching using new APIs introduced in Android 4.4.
                                think it is possible to insert the X7 to be able to see properly 24p 50p 60p video format without having to change the resolution every time?
