Minix Neo X7 - Finless 1.8 ROM
HELP
I got a MINIX X7 16GB / 2GB with external ariel - so definetly not the MINI - received it yesterday and started flashing roms - and although I can get all of them to work - I cannot get the 8gb parameter file to work - Finless 1.8 with 4gb / hardware Guru's / Wassers 2gb / justXBMC_v1.1.1_x7 no issues and Quickshot V2 all work - but I am really trying to get my MINIX to have an 8*8 parameter setting.
When I try Finless 1.8 with RKAndroidTool V1.37 and change the parameter to parameter8, the flash seems to go all ok - but all I win is a black screen output, no boot sequence nothing. It does go through the initial formatting screen - but nothing after that.
Same with 10gb parameter set?
Re-flash with the 4gb parameter and it all works again.
Just read through this thread and checked my box - mine is the Minix X7 216A model, I am thinking they have changed something - oh crap
I did not take a CWM of the original firmware - just jumped in with my eyes wide shut.
Anybody got any ideas?Last edited by gollygosh; 23 March 2014, 12:50.
After flashing the 4gb parameter file, go into settings>storage.
The top should say 3.69gb or so and NAND flash should say about 10gb. If it does not say that then you do not have 16gb.
Check that first.
Originally posted by Finless View PostAfter flashing the 4gb parameter file, go into settings>storage.
Check that first.
My best guess BOB is they changed something.
Originally posted by gollygosh View PostThis as they say is not my first rodeo - I definelty have the 16gb model - and yes when I flash any with the 4gb parameter - then yes it shows the values as you show them above.
However you do have to make sure you have the right loader.
You by chance didn't flash KitKat before did you?
If so you may have to go into MASK ROM mode to force the old loader.
Originally posted by Finless View PostIt doesn't work that way the parameter file simply partitions NAND.
Guru_X7_1080p_preloaded_04aR1_malipatch_public
Loaded with no issues at all.
Thought great so I then tried QuickShot_V2 then your 1.8 all these worked out the box and still do - Erase Nand etc, none are kitkat, that I think I have tried, simply speaking I know the dangers and decided not to try it, so tried Just XBMC etc and like I said I can flash them all back with a 4gb parameter file in place and they all work, change it to 8 and all I win is the initial MINIX logo - the formating screen - then re-start and then nothing.
So if the bootloader was screwed then when I put back on another rom with a 4gb partition wouldn't that also screw up and not load?
I actually didn't look at what the stock rom was, it may have been kitkat for all I know.
Confused.com
Confused.com
I doubt your box came with KitKat! So if you never tried it then you dont have a 2.xx loader.
That latest loader I have seen from RK for 4.2.2 JB is 1.24
You are flashing the loader when your doing all this correct? And it is 1.24?
When you erase NAND with the tool, what does it count up to?
Originally posted by Finless View PostPossibly not! The loader describes the different NAND chips that can be used and their blocking type. e.g. 512, 1024, 4096, 1 chip or 2, etc. So at 8GB partition it may be not spanning the chips properly due to a old loader. As new NAND chips come out and get supported by RK, RK always comes out with a new loader version to handle that.
Thanks for your help Bob - I know you don't have enough info (at least I don't think you do- to make a trully effective diagnosis. My intention was to warn others - and hopefully someone could U/L 216A rom before they made the same mistake I have.
Lets see what NAND chips you have.
Go download this tool
This is a new RK flash tool and will give all kinds of usefull information.
Put the X7 in flash mode and then run this tool
Now go to Advanced Function tab
Press the Read Flash ID button and write what it says down.
Now press the Read Flash Info button and write that down.
This will tell us if you have some different NAND.
Originally posted by gollygosh View PostGet FlashID Start
CS0: AD DE 94 EB 74
CS2: AD DE 94 EB 74
Get FlashID Start
Get FlashInfo Start
Man - HYNIX
Flash - 8192
Block - 4096
page - 16kb
ecc bits - 40
access time - 31
flash cs: 0 2
Other than that, only thing I can think of is you have a bad NAND memory area. Android should take care of that but maybe early in boot it cant handle that and mark off the area. Just guessing.
There are currently 2973 users online. 0 members and 2973 guests.
