(NEWLY RELEASED) CR11S/CS968 PRE-ROOTED (NOW VPNOPEN READY) 1080p 2MP Stock ROM LibMedia.so Hack Ready 20131205
You can get the Newly Released CR11S/CS968 PRE-ROOTED (NOW VPNOPEN READY) 1080p 2MP Stock ROM Libmedia.so hack ready 20131205 HEREhttp://www.sendspace.com/file/yj080y .... Here is the link to the app, "VPN One Click" https://play.google.com/store/apps/d...ck.VPNOneClick (No Side Loading Required).... Get the Fancy Widget Clock HERE http://www.mediafire.com/download/cn...dgets3.5.5.apk (Side Loading Required)... If you want more of the most popular XBMC add-ons, plugins, (FREE CABLE, *MASH UP,YIFY MOVIES, SPORTS DEVIL, ICE FILMS. 1CHANNEL, TUBEPLUS, USTVNOW, TGUN and MORE ), repositories zip files, then go HERE https://plus.google.com/communities/...20500984874818 ... The add-ons, plugins, and repositories zip files link will be located at the bottom of the right hand column in the blue links section TITLE (XBMC Plugins/Repositories Zip Files), click on this link ...! (*Mash UP:Rated The #1 Plugin Zip File For XBMC), (This ROM Build Is Confirmed By The Cloudnetgo Website)Last edited by Tech1; 31 December 2013, 00:40.Tags: None
Cant wait to flash it tonight.
1. Is the xbmc same as the old stock rom has? Would you recommend to install Justxbmcv4 on this rom.
2. For mx player I saw many codecs armv6 & armv7 versions which one is the correct one?
3. To launch the player selection menu which key to press using a PC keyboard or mouse? If using the factory remote what key can get this selection? I only sae option to play, download, add to favotries etc. on the movie list file and then on the source selection once clicked it would simply launch the default player. What am I doing wrong here?
Thanks for quickly producing this rom.
Rockchip Batch Tool 1.7
Originally posted by adionesis View PostHi Tech1, can a I be the noobest guy of the forum?
There is a guide to install a custon rom on the CS968?
(I used to flash my cellphone using the CWM, is the same here?)
The CS968 is already rooted.
Tried this ROM it works really smooth on the video part.
justxbmcv4 works good too will not passthrough via optical and the only changed I noticed was the static noise is gone and now it is silent and there is occasional pops.
Outside of xbmc the dts passthrough works quite good with mx player from an external samba drive.
Also xbmc will not gve me the choice of player selection. Pressing "C" on keyboard simply says "Play stream", "Download" "Add to Favourites" etc. but nothing on player selection.
Pressing the mouse click holding the same choices. Right clicking using mouse just takes me to back the previous screen.
I like the video quality on this ROM compared it to GEASS custom rom where there was alot of flickering noticed.
Has anyone else other than Tech1 able to get player selection working?
Originally posted by resansid View PostTried this ROM it works really smooth on the video part.
Try with the XBMC Remote for android, It´s a really good option.
You Remote
Originally posted by adionesis View PostThe "Play using..." option I founded under movie select in movies, press C or in my remote there is a special key.
There are currently 1191 users online. 2 members and 1189 guests.
