(NEWLY RELEASED) CR11S/CS968 PRE-ROOTED (NOW VPNOPEN READY) 1080p 2MP Stock ROM LibMedia.so Hack Ready 20131205
Originally posted by Tech1 View PostMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
reboots
Originally posted by clarkss12 View PostDid you plug yoI r c310 directly into your device, or are you using a powered usb hub? I am getting so many reboots and crashes, I removed mine. Also, are you using ethernet?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostAfter suffering from constant reboots, i installed the latest ROM for my tv01 from geekbuying. Reboots went away. So, l will have to conclude that some component is different. Do you think you could make me one of your awesome ROMs with the correct ROM for my devise?
Originally posted by adionesis View PostThe VPN config was not modify from the original stock rom (I think) if your question aims to that or you ask for a VPN "easy way" to get to work?.
Originally posted by Tech1 View PostMy belief/opinion is the same as yours, that some CR11S/CS968 MAYBE made by different manufacturers, this is my original statement .... I'm not saying, I'm 100% sure the CR11S/CS968 are made by different manufacturers, because I don't have proof ... If anybody say that I have said, they were made by different manufacturers, then they have taken my original statement totally out of context ... I just want to clear air with that one ...! We all have the very same devices basically, but I notice certain ROM builds affect some CR11S/CS968 different from others ... Where as some ROM builds will work like a charm on some CR11S/CS968, and on other CR11S/CS968, certain ROM builds will work with erratic behavior ... The c310 works very well with my devices via USB ... Now concerning your ROM for your device, that works best, give me a link to it and I will hook it up for you ....(lol)MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
MODDED ROM EQS-v2.0b
Did anybody tried this rom: MODDED ROM EQS-v2.0b?
Originally posted by lingam View PostDid anybody tried this rom: MODDED ROM EQS-v2.0b?
http://forum.xda-developers.com/show....php?t=2578411
Originally posted by Tech1 View PostYou can get the Newly Released CR11S/CS968 PRE-ROOTED 1080p 2MP Stock ROM Libmedia.so hack ready 20131205 HERE http://www.sendspace.com/file/d6jnu9 .... Get the Fancy Widget Clock HERE http://www.mediafire.com/download/cn...dgets3.5.5.apk (Side Loading Required)... If you want more of the most popular XBMC add-ons, plugins, (FREE CABLE, *MASH UP,YIFY MOVIES, SPORTS DEVIL, ICE FILMS. 1CHANNEL, TUBEPLUS, USTVNOW, TGUN and MORE ), repositories zip files, then go HERE https://plus.google.com/communities/...20500984874818 ... The add-ons, plugins, and repositories zip files link will be located at the bottom of the right hand column in the blue links section TITLE (XBMC Plugins/Repositories Zip Files), click on this link ...! (*Mash UP:Rated The #1 Plugin Zip File For XBMC), (This ROM Build Is Confirmed By The Cloudnetgo Website)
thanks for this rom, but is a pree-rooted 5 MP Version avaiable?
TNX for Information
5MP 1080p Libmedia.so Hack Ready ROM Build
TNX for Information
There are currently 1897 users online. 0 members and 1897 guests.
