What button is that (where is its position on remote)?
(NEWLY RELEASED) CR11S/CS968 PRE-ROOTED (NOW VPNOPEN READY) 1080p 2MP Stock ROM LibMedia.so Hack Ready 20131205
Originally posted by Tech1 View PostVery good awesome, glad you found it ... Now let's get your optical audio Settings fixed via the CS968 and the JustXBMC app ... What's the name of your remote ...?
Now I am wondering is there many Justxbmcv4.apk versions out there? Do I have the correct one installed?
I donwloaded this from the first post where you added the link saying it is lewy's version.
Is this the same justxbmc you are talking about?
No Problems With This ROM
Originally posted by nazmi28 View PostIs there a problem with the reset ROM?
Do you have WiFi problems?
1080 Do you have video problems?
devamlı rom yüklemek sıkıcı...
gerçekçi bir rom mu..
Measy Rc13 I got a mouse ..
speaker and headphone does not pass ..
Did you do the experiment ...
Does it work on this rom?
Originally posted by resansid View PostHi Tech1 I am using the xbmcv4 but when I press "C" or mouse click and hold, I dont get the "PLay using" option.
Re: CR11S/CS968 PRE-ROOTED 1080p 2MP Stock ROM LibMedia.so Hack Ready 20131205
Originally posted by resansid View PostWhich remote do you have for this unit. Mine is from Geekbuying the TV01 model but I have seen remotes can vary if ordered from different retailers like merimobiles or Aliexpress.
Enviado desde mi GT-I8190L mediante Tapatalk
Limedia.so Hack
x
CR11S_cloudnetgo_ap6210_Cam2518_201301205_update
Do you can list change you made in relation firmware original?
e.g.:
1. ...
2. ...
...tks...
Logitech c310 cam
Originally posted by Tech1 View PostThe only things I did were to PRE-ROOT the ROM build and add the Libmedia.so hack software by Stafstrom, that's it .... I'm waiting on my Logitech c310 cam to come in to test with this ROM build ....MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Test Run
Originally posted by clarkss12 View PostI have this cam, could not get it to work with my T428, but will try it on my TV01 now. uh, just plugged it in, but how do I select the cam. The mic showed up in the sound device section but really don't know how to check it, since it already has a camera/mic built in.
Originally posted by Tech1 View PostIf any USB cam should work with this ROM, it should be the Logitech c310 ... Plug the c310 in the USB port beside the Micro SD Card Slot ONLY ... Power cycle your CS968, once your CS968 comes back up all the way, click on the build IN "Camera App", it should work ... Give it a test run, let me know how it works, thanks in advance ...!Last edited by clarkss12; 21 December 2013, 03:10.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
My Theory Was Correct About The LogiTech c310 Cam
Originally posted by clarkss12 View PostI did as you directed, but after power cycle, the camera app crashed as soon as I opened it. The camera app will work if I plug the c310 after the device is booted. I also, do not see and "build IN in the camera app.>>>> ok, did another power cycle with c310 plugged in. Icon on camera to switch cam showed up. I was blown away, the quality of the picture was just fantastic.
AuTuTu Benchmark (Device Info)
Originally posted by webipsum View PostUnfortunately, neither of the two firmwares, worked fine on my device.
Only works 720p. 1080p not.
Tks.
There are currently 1667 users online. 3 members and 1664 guests.
