(NEWLY RELEASED) CR11S/CS968 PRE-ROOTED (NOW VPNOPEN READY) 1080p 2MP Stock ROM LibMedia.so Hack Ready 20131205
Originally posted by hanu_blr View PostLast edited by Tech1; 21 December 2013, 12:26.
Firmware Released Date Confirmed At The Cloudnetgo Website
According to http://www.cloudnetgo.com/CR11S2M.htm the Cloudnetgo website, I can now confirmed , the NEW CR11S 2MP 1080p software was released by Cloudnetgo on 12/05/2013 ....Software NameSoftware VersionSoftware SizeRelease DateCR11 / S20131205_2M_1080P289.38M2013-12-05Software DescriptionFor CR11 / S 200 million cameraLast edited by Tech1; 21 December 2013, 13:13.
Originally posted by Tech1 View PostWhat test are you using to determine 720p only work on your device ...?Originally posted by Tech1 View PostThe device info comes from the current on board ROMs kernel ... Use the AuTuTu Benchmark app to see your device info, it should say in the "Resolution Block" 1920x1080 ....!
Visual test, because if you set screen to 1920x1080, the screen goes black and the resolution does not change.
The firmware I'm using (see asssinatura) features 1920x1080 resolution, including the home of Android.
When I have extra time, I will reinstall the firmware and do a test with AnTuTu.
Grateful for the attention.
2MP Cam 1080p ROM Build Confirmed By Clougnetgo
no voice search
Originally posted by Tech1 View PostGood news, my theory was correct ... Ok, also you should be able to get the Logitech c310 to work with Skype, Hangouts, Yahoo Video Messenger and several other video messenger services ... My Logitech c310 will be in tomorrow ... Thanks for doing the test ...!MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostOne other thing I have noticed is that there is no voice search using either of the mics, the one built in or from the C310 mic. I have a MK818B with built in camera/mic and the mic icon appears in the search bar or most other apps. I can use the assistant to do voice search. With my TV01 (cs968) there is no mic icon anywhere in the apps. The voice recorder does work with both mics, so I know the mic input is working. I have not tried any video conference apps yet. Do you voice search with your device??Notice the "Mic Icon" in the Google Search Bar ...! My c310 will be in later today, will give it a full test run with Skype/Yahoo Video Messenger and Hangouts ...
According to the user manual, we are instructed to do the voice test with the built in "Sound Recorder App" like in the bottom photo here, before doing a video conference/Skype video ...
Originally posted by Tech1 View PostNotice the "Mic Icon" in the Google Search Bar ...! My c310 will be in later today, will give it a full test run with Skype/Yahoo Video Messenger and Hangouts ...
Originally posted by clarkss12 View PostYes, I see the mic icon on your screen shots. I did do the voice recording with both mics, and they both recorded. I am not sure what I am doing wrong. I am using the same rom and guess my device is the same as yours. I will keep trying. Wondering if I should reflash the rom. Also, I do get a lot of reboots, but getting fewer each time I use it......
Originally posted by Tech1 View PostIf you want the mic in the Google Search bar, go to the market and install the new updated Google Search app ... I have not experienced any reboots on either of my devices ...MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
voice search
@tech1,
i installed ur 1080p 2mp 20131205 rom, and also downloaded the stock rom from cloudnet 2mp1205 rom. I tried both the roms, once thing i noticed is that, the icon/text are bigger on these rom, like 720p rom. I tried an older 2mp 1080 rom 1020 (CR11S_cloudnetgo_ap6210_1080p_20131019_root_updat e), in this icon/text looks smaller (like 1080p). I suspect that 1205 may not be a 1080p rom (i might be wrong as the lcd density on this rom might be lower ).
does the justxbmcv4.apk has the builtin libmedia.so hacked file or we need to install the patched so file separately ??
No More Ugly Cam
Originally posted by clarkss12 View PostI have this cam, could not get it to work with my T428, but will try it on my TV01 now. uh, just plugged it in, but how do I select the cam. The mic showed up in the sound device section but really don't know how to check it, since it already has a camera/mic built in.
There are currently 1408 users online. 0 members and 1408 guests.
