JDfense --->I8160
(NEWLY RELEASED) CR11S/CS968 PRE-ROOTED (NOW VPNOPEN READY) 1080p 2MP Stock ROM LibMedia.so Hack Ready 20131205
NEW VideoMix-2 App Released
Their is a NEW "VideoMix-2 App" just released, that can be found in the right hand column in the bottom blue link download section HERE https://plus.google.com/communities/...artnerid=gplp0 .....
new guy problems..
hello..
so i got one of these & it your orginal rom loaded well but theres just a few things..
one is.. i cant install anything..
the other is the wifi doesnt work..
and then of course i dont have a back up of my original rom to share the wifi files..
ive have "let unverified apps install" checked but my backup apks will not load from the apk installer..
other than that thanks for the work.. its been fun so far..
update: got droidmote to install so google play will install apps but will not execute from ics file manager. super user thing? idk. any help/tips/tricks would be cool
details..
hello..
i was just about to try your tv01 test rom..
so.. on this rom I am able to install apps from the play store and my goal to get root & droidmote working is a success..
yet.. i can not install any apk's from either the preinstalled apk installer or from ics file explorer..
i have checked the correct box to allow "unknown sources" apps, etc..
but if i could just install anything i would stick with this rom..
i cant install frodo xbmc. nexus 3d.
has anyone else reported this problem or is there something im not doing?
good morning..
no, not getting any error message.
when i navigate to the apk file it will not allow me to install anything. I can highlight cancel, yet the install button does nothing.
Being new to these devices & root superuser I was wondering if maybe I needed to set up any special permissions to write to disk or.. well I dont know.
other than that the picture is fantastic.. there are frames being dropped streaming but I believe you recommended installing an updated xbmc.. which i cant yet..
idk. its odd.
problem identified
alright.. so after scratching my head & reinstalling I came to a point when I installed "droidmote"...
and then was unable to install anything after that..
that was my problem..
I am using ..or trying i should say.. to use the droidmote to have touch screen control for games..
why that app blocks apk installs is just overreaching to me..
thanks again for the rom.. and now I just need to figure out how to get the wifi driver.. or what version wifi I have and all that mess..
peace..
Originally posted by reeferman View Postalright.. so after scratching my head & reinstalling I came to a point when I installed "droidmote"...
peace..
Get the NEW UPDATED ShowBox And VideoMix Apps
Get the NEW UPDATED ShowBox And VideoMix apps Current Versions found HERE https://plus.google.com/communities/...artnerid=gplp0 ...
Originally posted by ttherapo View PostJust installed this, but wifi is not working. Probaply different mainboard...any suggestions?
*8188 CS968 (Wifi Works) Pre-Rooted
Get the NEW ROOTED 8188_GT-19300_htc_t018_public_Mtk_20140127 HERE http://www.sendspace.com/file/4z0woo ....
*TV01 CS968 Pre-Rooted HERE http://www.sendspace.com/file/wtby9s ....Last edited by Tech1; 18 February 2014, 05:13.
There are currently 2467 users online. 1 members and 2466 guests.
