Pipo M6 Pro RileyROM 1.6 [Last Stable Jellybean]
    Yes, I can also reduce the wifi power, if it would be beneficial.
    The baseline is 80%...I increased the 1.6.1 to 100%.
    Could you please send my the file with wi-fi power decreased from 80 to 60% ? Just to test it with my tablet and the modified antenna?
    In this way I think I could save battery...
      Hihi Giouncino is and always will be the everlasting battery saving guy.
      Happy New Year Giouncino. Your work is appreciated !
      Sent from my W100S
        Yes...but that would involve giving up my secret..hahahaha!!!!!!!!!
        Look for a PM.
        Randy
          Hi Pipo2000! Happy new year to you too!
          As always you got the point!
          Now I have the tablet opened waiting for my new 3G and wi-fi/BT antennas (both bought on e-bay, they are on route now).
          My new Wifi/BT antenna comes from iPad mini (hope it will work...) and 3G comes from HP laptop.
          I already replaced coaxial cables with low loss aeronautics ones (that are also a lot bigger, finger crossed to be able to close the tablet again, otherwise I need to change again the cables...)
          I replaced also the battery (that was not fully efficient) with a new original one.
          I made all the soldering directly on the motherboard...I was a little bit worried of it but for the moment everything is still working.
          I'm still able to connect with my router even if the antenna is not connected if I remain within 2-3 meters from the router (I ruined the original one during soldering... it is very delicated...).
            Look for a PM.
            Ok, Randy thank you very much, I'll wait for a PM from you.
            I hope I will have my new antennas within the week-end.
            I would like to close the tablet very soon.
            I will open a new thread to identify all the antennas inside the M6pro and eventually to change them, in particular 3G antenna seems not so sensitive...
              First Flash!
              Hello everyone,
              I just joined up but have been reading since November when I purchased a M6 Pro 32 WiFi only from GeekBuying and have been *Very* pleased with the tablet as well as the prompt accurate service from Geekbuying.
              I have been on stock until today, when I just flashed RR1.6 (80% wifi release). Nice. Thank you sooo much for all the contributions you have been doing for the Pipo users. I would like to send Randy a contribution but after looking around on Freaktab, I never found how to do it... Randy, can you direct me how to send you money? I was going to PM you but I thought I might post publicly as a reminder for any that can support Randy in his efforts....
              Steve
                Randy, I can confirm that DEEP SLEEP issue is definitely SOLVED also with "stock" libril... file.
                  That sounds great. Looks like v1.6.1 is unnecessary unless you need to have stronger wifi signal.
                  Randy
                    Will definitely change my rom to the latest one! Currently use RR1.4.
                    Thank you Randy & others who contribute!
                    Sent from my ZP990 using Tapatalk
                      Hello,
                      I bought m6 pro 32gb about 3 weeks ago and i used 1.5.1 ROM. Yestarday i updated to 1.6.1 (i think my question is also about 1.6). I noticed that after reboot MODEM POWER checkbox always turns on. I think it means that modem begin to consume power after reboot. And there was no such thing in original ROM. I really like 1.5.1 rom and i apprecite Randy for his great work! And i wounder if that somehow could be fixed?
                      I read (somewhere) suggestion that i must turn on AIRPLANE MODE and enable wifi (if i need it), but i still see that modem consuming power (yellow and red line in battery settings). And i am not sure that AIRPLANE MODE helping me in this case.
                      Of course this is not a great problem, and as i see that 1.5 and 1.6 roms working better on my device (on my opinion).
                      Thank you for your answer.
                        I noticed this also when you look at Settings / data usage / More / Mobile Networks, Modem Power is ticked and you can untick it but after a reboot it's ticked again.
                        Sent from my Pipo M6Pro running RileyRom 1.6
                          exchange of parts
                          Could you share the link to the battery- or at least specifications to find such on ****?
                          Did you consider to change speakers, too? There were a lot of shouting about these some time ago...
                            these are battery data (written on it):
                            PTI-01005000MC222S1P0000000-R
                            PL4574129P 37Wh 7.4V MD09
                            The battery spec are: 5000mA/h * 7.4V 37Wh
                            I'm not interested on changing speakers. For me the stock speakers are enough.
                            And I think I have soldered enough components inside my tablet .
                            Did you test Viper4Android App? This could help to improve speakers volume.
                              parts exchange
                              The battery spec are: 5000MA/h * 7.4V 37Wh
                              I will try today Viper4 app in the evening.
                              I just wonder where I can find battery with spec you provided. Will try to look for on ****- did you use some specific "key words" to look for? assume there are 2 batteries with specs you provided, connected?
                                So why dont you include the "stonger wifi signal" in the current 1.6 and have only this version available for download ?
