Pipo M6 Pro RileyROM 1.6 [Last Stable Jellybean]
Help with flashing
Hi!
I am looking for some help with flashing Rileyrom.
My computer must have installed some drivers earlier. Because when I follow the First time user guide and click "reboot to flash mode" in Rom_flash_tool_137 it can't do anything. I get an error and am stuck.
I've read that it says that I woun't be able to flash it with my computer... or something like that.
When I manually put the tablet in flash mode (volume + and power) my computer reacts with "A unknown usb-device". When I get that message I try to install the drivers. Rightclick in Devicemanager and point it to the correct Drivers. But it fails.
Can someone give me some advice please! It would help me alot. Any developer who can help me out? Anyone who has had the same problem and can point me in the right direction?
Does your flash tool recognize the device in "mass storage mode"?
If so...launch the RKBatchTool app...provided in the kit. Click the "switch" button to reboot to flash mode.
Make sure USB debugging is turned off in developer settings.
Be sure to use the USB cable that came with the tablet.
Sent from my SAMSUNG-SGH-I537 using TapatalkRandy
Originally posted by rrileypm View PostDoes your flash tool recognize the device in "mass storage mode"?
It didn't rcognized it in mass storage mode. But the other tool did recognize it when ust connected as usb. When I pushed switch it got into flash mode (I guess) but then I am stuck at the current problem where I can't install the drivers manually. (rightclick in device manager and so on)
USB-debugging is turned off.
I am using the original cable from pipo.
I am at windows 8.1.
Any other ideas? Is there any way to destroy the current drivers? Am I the first to have theese problems? (Am I doing it wrong?!)
Thanks!
Thanks!
win 8.1 is not supported!
Win 8 and below works perfectly.
I use Win8 and another PC with Win7if you appreciate my efforts this is the link for any donation:
Hopefully it will get support in 8.1 soon. I need to install the RileyRom to get this crap to work good. ^^
It think this tablet works almost as bad and slow as a aunts computer wich is infected with maleware, viruses, webbrowser extensions and other crap.
Well. Then I don't need to try to install it anymore. I'll maby get back here in the future to see if it supports 8.1.
I'm out!
Surely you can find an old PC laying around with an older version of Windows. Or maybe a friend with one.
The problem won't be solved anytime soon because Microsoft did away with the method used by Rockchip to communicate in 8.1.
Originally posted by dcbede View PostHi Benjamin, if it could help, I use "power toggles" from the Google play. You can set up to 16 quick switches/links on top of the screen as it does the symbol bar included with android.
Regrettably "power toggles" does not offer the possibility to toggle the "modem power".
Does anybody have another idea?
Thank you.
Originally posted by moonwalkie View Postdid you try a full format and reinstall of the firmware?
I will try 1.6.1 and the KitKat version to see if things improve.
Thank you.
Hey guys, I posted this in the 1.5 thread but I am gonna move here because as I upgraded to 1.6 and the issues are from it.
1-Notice the yellow and red lines in mobile data signal. The yellow means it's searching for signal right?
2- Waking the device up after 9 hours the battery showed 51%,the same as I before going to sleep, but when I started to use it went from 51 to 42 in 20 minutes of use. Is this normal?
3 - turned on air plane mode and as you can see the mobile data is still yellow in the last minutes of usage. Any ideas? Should I make the trick of removing the libli file?
Sent from my M6pro using Tapatalk
Guys I have a couple of dumb questions.
1-is there any difference in performance installing a kernel? If there's not, which differences does it make?
2-where can I find them to download and a tutorial step by step and which are the best?
I am asking this because my pipo m6 pro isn't running very smooth(I am running the RileyROM 1.6).
Or maybe I am expecting too much for this tablet, the fact it's a quad core I wanted it to be a bit faster like scrolling a website or even playing candy crush, the candies aren't falling smooth in the screen lol.
Enviado de meu SM-N9005 usando Tapatalk
Review this thread for the kernels...links to them are posted.
To flash a kernel, use the flash tool. Uncheck everything except the kernel. Direct the flash tool to the kernel you want to flash. Then flash ROM without erasing idb.
The more stable kernels are the ones with overclocked DDR.
Try not to double post the same questions. I saw your post on the 1.7 thread...there aren't any custom kernels for the KitKat ROM yet.
Originally posted by rrileypm View PostReview this thread for the kernels...links to them are posted.
Sent from my SAMSUNG-SGH-I537 using Tapatalkif you appreciate my efforts this is the link for any donation:
There are currently 1969 users online. 0 members and 1969 guests.
