Sent from my M6 using Tapatalk
Pipo M6 Pro RileyROM 1.6 [Last Stable Jellybean]
Originally posted by Ayscii View PostBest for me has been the rileyrom 1.7 KitKat with the kernel randy supplies with it. It has been just darn stable for me. I about daily had to use the reset pin under stock pipo and also the rilely 1.6. Under the KitKat 1.7 Riley ROM it has been rare. I just today tried some of the other kernels and most of them had boot hangs for me, a couple couldn't make it through Antutu so I went back to the kernel randy has with the 1.7 I get a 19500+ score with it anyway and it has been so smooth..…
I do miss the GPS, that was one of the reasons I chose the M6 pro in the first place.... I'm using a fake GPS program to force location for some apps....
You can try this.if you appreciate my efforts this is the link for any donation:
Thank you I will give use the rom you stated after I test everything on the tablet.
Regards
Brian
Originally posted by levicius View PostI am using rileyrom 1.7 and the kernel provided by giouncino,called claro .I am getting 20300 in antutu and its stable.
Originally posted by Ayscii View PostAlso, make sure you check everything while still stock, like the camera, flash,wireless and speakers.... In case you had to send it back for some reason.....also make sure you read everything here and the first time guide and all before you flash.....
Thank you I will test as you state, and then flash!
Great place for advice!
Brian
(Using the 1.7 kitkat) I tried the claro kernel again and it did similar, failed at 21% floating point in antutu, locking up, failed rebooting and had to manually enter reflash (holding +vol and power while connected up by usb). Then I flashed the kimmen stock ddr and it seems to be working fine and steady adding about 350 points in antutu. Thanks, giouncino!
Re: Pipo M6 Pro RileyROM 1.6
Originally posted by Ayscii View Post(Using the 1.7 kitkat) I tried the claro kernel again and it did similar, failed at 21% floating point in antutu, locking up, failed rebooting and had to manually enter reflash (holding +vol and power while connected up by usb). Then I flashed the kimmen stock ddr and it seems to be working fine and steady adding about 350 points in antutu. Thanks, giouncino!
This is happening with some people, I was getting the crash in antutu while 3d testing ,I still don't know the reason but after flashing the 1.7 ROM again the kernel Clark is working like a charm.
Enviado de meu M6 usando Tapatalk
- the tablet is powered on in "steady state" for at least 2 minutes
- switch off Wi-fi
- remove any micro-SD
Wtih only RAM overclock you can gain at least 1000 points on antutu.if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View Post350points of gain is extremely low. Try ANTUTU test again. For reliable result make sure that:
- switch off Wi-fi
Enviado de meu Nexus 7 usando Tapatalk
Originally posted by superbit64 View PostWhich one is the one with with overclocked RAM? Does it increase battery duration or the otherwise?
post #381
This will not affect battery duration, or a negligible increase due to 100mV decrease of RAM voltage.if you appreciate my efforts this is the link for any donation:
Hi Everybody,
I just received my PIPO M6 Pro yesterday and flash it immediately with RileyROM 1.6.1 !
It works perfectly like a charm for the moment except 1 thing but I don't know if it is a global Android bug or just on RileyROM ! I have set 2 users account (one for me and an other for my girlfriend), and I can change the wallpaper on mine but not on her account, the wallpaper still black. I have change it a lot of time and I have always the message "wallpaper change successfull" but still always black. Same if I restart the tab !!! Strange !
Anybody have this problem also ?
Thanks for your help and thanks a lot for Rriley for his great job ;-)
Originally posted by giouncino View Posthttp://www.freaktab.com/showthread.p...-models/page20
post #381
Sent from my Galaxy Nexus using Tapatalk
Originally posted by jsager View PostThis is for kit kat, version 1.7 of RileyRom. Will this work with 1.6 or is their a different kernel needed? This is great stuff you guys are doing.
I've not prepared a RAM modified only for JB.
The kernels are not compatible!if you appreciate my efforts this is the link for any donation:
There are currently 1971 users online. 0 members and 1971 guests.
