Sent from my SAMSUNG-SGH-I537 using Tapatalk
Pipo M6 Pro RileyROM 1.6 [Last Stable Jellybean]
Hmmmm...I forgot about that. Do they all boot OK?
Sent from my SAMSUNG-SGH-I537 using TapatalkRandy
There is one with only the RAM overclocked.
For the others depends on how is lucky your CPU!if you appreciate my efforts this is the link for any donation:
Re: Pipo M6 Pro RileyROM 1.6
Originally posted by rrileypm View PostReview this thread for the kernels...links to them are posted.
To flash a kernel, use the flash tool. Uncheck everything except the kernel. Direct the flash tool to the kernel you want to flash. Then flash ROM without erasing idb.
The more stable kernels are the ones with overclocked DDR.
Try not to double post the same questions. I saw your post on the 1.7 thread...there aren't any custom kernels for the KitKat ROM yet.
And I am sorry about the double post, won't happen again.
Sent from my M6pro using Tapatalk
Originally posted by stefanmiler View PostYou can re-enable this setting by changing a line in the build.prop:
ro.rk.resolution_enable=false, change to =true
After a reboot you will then have the option to select HD or Normal in the display settings.
I was downloading the kernels to try with the 1.6 RileyROM and downloaded the cpu z app to check some settings about my tablet.
And I jut saw that the cpu isn't the rk3188 as was suppose to be. Is this rk30sdk model the same or the guy that sold me the tablet fooled me with another cpu inside?
I am getting a 17300 antuntu with stock kernel, is this normal?
That is just what Pipo put in the build.prop. Don't worry, you've got a genuine 3188
Originally posted by rrileypm View PostThat is just what Pipo put in the build.prop. Don't worry, you've got a genuine 3188
That's because you are running v1.7. The developer put in different information.
ERRATA CORRIGE
Randy I did a mistake:
also 1.6 has no deep sleep, these Chinese don't learn....
I don't know why I saw deep sleep working on this ROM.
So the possibility is still to change the usual libril file as you did on 1.6.1
I hope that as soon as an official Kitkat rom is released we will be able to find a solution to enable deep sleep there.
I suppose that the JB libril will not work on Kitkat.
This week-end I will complete my "Frankenstein" M6pro tablet (taking some pictures of its internal) and I could do some testing.
I will create a new discussion on 3G/Wifi/BT antenna replacement and ALL antennas relocation (GPS included) to improve sensitivity.if you appreciate my efforts this is the link for any donation:
I have not even tried adding the libril file to a KitKat ROM yet...I was waiting to see what the baseline was with deep sleep.
It depends on how much time we need to wait more to have a new version of kitkat!if you appreciate my efforts this is the link for any donation:
Best for me has been the rileyrom 1.7 KitKat with the kernel randy supplies with it. It has been just darn stable for me. I about daily had to use the reset pin under stock pipo and also the rilely 1.6. Under the KitKat 1.7 Riley ROM it has been rare. I just today tried some of the other kernels and most of them had boot hangs for me, a couple couldn't make it through Antutu so I went back to the kernel randy has with the 1.7 I get a 19500+ score with it anyway and it has been so smooth..…
I do miss the GPS, that was one of the reasons I chose the M6 pro in the first place.... I'm using a fake GPS program to force location for some apps....
Sent from my M6 using Tapatalk
There are currently 1974 users online. 0 members and 1974 guests.
