Pipo M6 Pro RileyROM 1.6 [Last Stable Jellybean]
    GPS is missing...
    and in the info the model number is M6 (and not M6pro)....
    The scrolling in the settings menu was not as smooth as with the RileyRom
    but the lauchner scrolls as smooth as the Stock JB Launcher and also apps seemed to start smoothly.
    Because of the missing GPS I went back to RileyRom 1.6.1 for now... ( or at least I try )
    I'm a little sad about the mode lnumber fact
      kit kat
      gps dont work (
        it works :-)
        thanks sooooo much riley !!!!
        and GPS works
          Thanks to all for the info. Funny what goes on when you sleep. I will download the update and cook a new ROM today. Luckily...I have an M6 Pro to test.
          Sent from my SAMSUNG-SGH-I537 using Tapatalk
          Randy
            Update? Witch update?
            Don't found one by Pipo....
            but sounds good
            Edit: sorry... good morning Randy and happy new year!
              See post #54
              Randy
                New KitKat RileyROM!!!!!!!!
                v1.7 is now ready to download.
                I've tested it on my M6 Pro and it works quite well!!!!!!!!
                Here's the new thread:
                Randy
                  Wifi not working
                  I tried flashing Pipo_M6_Pro_RileyROM_1.6 and Pipo_M6_Pro_RileyROM_1.6.1 on my pip m6 wifi and everything works fine except for the wifi. I found a rom called Pipo_M6_wifi_RileyROM_1.6.zip and the wifi works correctly on that. Is this correct, should I only use roms with wifi in the name?
                    You have a M6 and not the M6PRO!
                      Crap, so there is a m6 wifi, m6 3g and then a m6 pro and not to mention the m6 max. . Pipo madness!
                      Seeing as it's only the wifi that doesn't work would it be easy to just replace the wifi driver?
                        M6 and Max are the same, there is only differences between M6 and pro... pro has a GPS Module. Both types are available, Wifi-only and 3g.
                        Best thing to do for you is looking for a RileyRom for the M6 (and not pro)...
                        There should be plenty to find via a big search engine
                        or you look a few posts further up... the M6pro RileyRom 1.7... It has the new KitKAt Android and is apparently supposed to be for the M6, not the pro.
                        Greetz
                          Stuck at recovery after flash
                          After flashing 1.6 Rom i am stucked at recovery mode with android and red triangle in it. Now windows doesnt recognize tablet and flash tool doesnt find RkAndroid. Tried resetting but nothing and also tried pushing volume + and On button but cant get in flash mode.
                          The only options i have in recovery mode are:reboot-apply update from ext storage-apply update from cache-wipe data factory settings-wipe cache partition.
                          Is there any other mode to get tablet in flash mode?
                          Ok, Solved unsoldering and soldering after a few seconds the red wire of battery.
                          But after flashing rom 1.7 i cant go back to 1.6(tried twice with 1.6 and 1.5 version but after flash tablet stucks at recovery). Now i'm using 1.7 KitKat
                            Greetz
                            this kitkat COULD be for the M6, but it is definitely for the M6pro (even with the lack fo GPS) because wifi is working for our M6pro so it is better to NOT install this firmware on an M6 non pro, in my opinion.
                              Re: Pipo M6 Pro RileyROM 1.6
                              Did you check the loader on 1.6? That MUST BE DONE...and erase IDB...maybe even twice...before flashing.
                              Randy
                                R: Pipo M6 Pro RileyROM 1.6
                                Done it just right now. Awesome :-)
                                It worked. I'm back to 1.6
                                Thx Riley
                                Inviato dal mio Galaxy Nexus utilizzando Tapatalk
