Neomode Custom Rom MK802IV / MK809III 2.1 BETA RK3188-T and RK3188
JUST PERFECT!
I tried the ROM on my mk802iv. It's working perfect. Fast and stable.
I'm using the 1800 cpu gpu stock and 1500 ram sam kernel and everything runs great!
Perfect neomode!!
Using a gpu oced kernel, i get the same 446mhz top freq in dmesg. This is my only unsolved problem!
If you can help neomode i would be gratefull!
Thanks anyway!!
Originally posted by ynot123 View PostHave the same problem, went back to 1.9a kernel3 with no issues.it would be great if you could comment on this.
Originally posted by FrankieDedo View PostOk, after A LOT of tribulation, i had found a configuration that (probably) have stopped every major problem in video playback.
This is my config:
MK809III v2 (AP6210 and RK3188, not the "T" one)
Neomode Custom Rom 2.1
Kernel included in the NCR, overclocked with rkpatchomatic, with CPU freq steps, in GHz: 1.00,1.20,1.42,1.60,1.80,1.92 GPU freq set to 798 Mhz and DDR set to 800 Mhz (that with DDR, i guess, it's an effective 1600 MHz)
This is what i get in Antutu, but i had to clock the cpu to 1,2 Ghz min/1,8 Ghz max because at 1,92 was unstable...
Anyway, i can give you the modded kernel, or the rkpatchomatic source file i've changed.
I'm testing it now, with the largest 1080p movie i got, attached to the TV's usb, from a 3TB HDD... and so far it is going really nice!
Bye guys!
Can you share the rkpatchomatic file u changed?? And the kernel pls. It is a nice score on antuntu u got there
Originally posted by locolars View PostCan you share the rkpatchomatic file u changed?? And the kernel pls. It is a nice score on antuntu u got therei'll not post it again to avoid confusion
Anyway i'd like to try a benchmark with 1.8 Ghz min/1.92 Ghz Max to see what happens
The funny thing is that my stick has only the "flat" metal heat sink, and after a movie and some benchmarks at 1.8 i was able to touch it without burning myself O.O I think it's a good thing
EDIT: link to the post http://www.freaktab.com/showthread.p...l=1#post141739Overclocked Kernels for Neomode's roms -> [KERNEL][AP6210] Overclocked kernels for Neomode ROMs (2.1/2.0/1.9a/1.7)
Originally posted by FrankieDedo View PostYes, i'm using the 2.1 beta, with the kernel.img you find into the rom .zip as i said i used rkpatchomatic on it... anyway, here is the download.... oh, and obviously BE CAREFUL!!! Don't come here and say that i ruined your stick
If you have a normal RK3188, i recommend a cpu frequency range between 1,0/1,2 GHz and 1,6/1,8 GHz... i tried to set the maximum freq to 1,92 GHz but it isn't really stable, and it needs much more power to run.
The best thing is to use rkpatchomatic by yourself (editing the overclockomatic source, it's really simple) and setting your own frequency steps, and choose your own GPU/RAM freq values too
Here is the kernel...
DOWNLOAD: http://www.mediafire.com/download/j2.../kernelmod.img
just to remember, the values that i have set here are:
- CPU frequency range = 1.008/1.200/1.416/1.608/1.708/1.800/1.920 GHz
- GPU frquency range = 400/600/798 MHz
- RAM frequency = 800 MHz*
*As i said before, with DDR the effective frequency is 1600 MHz (Double Data Rate) but that doesn't really matter, i guess
Originally posted by mymkv View PostI always use tool to apply rom whatever comes with the Neo's download. Do you think you could write steps how to use rkpatchomatic ? never used it before. Thanks in advance.for any details i send you to phjanderson's original post: http://www.freaktab.com/showthread.p...rk3188-kernel!
Anyway it's very simple:
Code:1) Download and install PERL (During the installation say yes when it asks you to put PERL into PATH variable) [URL]http://www.activestate.com/activeperl/downloads[/URL] 2) Download rkpatchomatic from phjanderson's github: [URL]https://github.com/phjanderson/rkpatchomatic/archive/master.zip[/URL] 3) Extract rkpatchomatic somewhere. 4) Put the kernel you want to patch into the folder that contains the file "overclockomatic3188". 5) Open a cmd window and write: cd *insert here the path to the folder where kernel and rkpatchomatic are*. 6) write this into cmd: perl overclockomatic3188 kernel.img (or whatever the name of the kernel is). 7) do what it tells you, i can predict that with our sticks you'll have to enter, in this order: 6, 7 and 8. 8) Wait for the kernels to be written, it writes every possible combination. 9) Flash it! :) For every change you want to do to frequency tables i recommend to you to use Notepad++ to open the overclockomatic3188 file, and activate the Perl language (under Language menu) As i said, if you want more detailed informations with the editing of rkpatchomatic, go to the phjanderson thread ;)
Originally posted by FrankieDedo View PostOkfor any details i send you to phjanderson's original post: http://www.freaktab.com/showthread.p...rk3188-kernel!
Originally posted by vihru View PostIs that kernel compatible with 1.9a? And do i only flash that with rktool? And how? Only chose kernel and press run?
The flashing mode is the same as usual: Use the rktool you find into your rom pack and pick only the kernel checkbox (remember to point the path to your correct kernel name)
Ok guys for every overclocked Neomode roms kernel questions i opened another thread: http://www.freaktab.com/showthread.p...835#post142835
It is in construction but it already has 2.1 downloadsOverclocked Kernels for Neomode's roms -> [KERNEL][AP6210] Overclocked kernels for Neomode ROMs (2.1/2.0/1.9a/1.7)
There are currently 4113 users online. 1 members and 4112 guests.
