Neomode Custom Rom MK802IV / MK809III 2.1 BETA RK3188-T and RK3188
Default sound to mediatek
Hi all,
in my 802IV with 3188-t I have some flickering but the most annoying thing is that sound defaults not to HDMI but to Mediatek (it comes from my F-10 pro) so each time I power the thingie up I have to go to settings and change it.
Any chance to solve it?
Neomode: you suggested using DDR overclock, I tried to use sam overclocked with 1.7 but to no avail;should I try it with this 2.1 just putting the overclocked kernel in place of yours?
Thank you
RKMan
Originally posted by neomode View PostYes you can use a Kernel from Sam321.
I make this firmware to use old kernels with T CPU.
Neomode
Originally posted by Gianca90 View PostHi, you can partially resolve the blinking/flickering problem by connecting the tv stick directly to the hdmi tv port. (without using the cable)
For me the the screen now doesen't go on and off every 2 sec; but for every overclocked kernel I have an image distorting problem (lesser in 1080p and overclocking the gpu)...
Neo 2.1 in combination with oc by Sam works really good but black screen coming and going every 2 sec.
Neo 1.9 with no overclock instead is very stable and with no lags: but I am sad without overclock..
P.S. Gianca stesso problema qui..con la Rikomagic 802IV e proc. 3188-T
Ok, after A LOT of tribulation, i had found a configuration that (probably) have stopped every major problem in video playback.
This is my config:
MK809III v2 (AP6210 and RK3188, not the "T" one)
Neomode Custom Rom 2.1
Kernel included in the NCR, overclocked with rkpatchomatic, with CPU freq steps, in GHz: 1.00,1.20,1.42,1.60,1.80,1.92 GPU freq set to 798 Mhz and DDR set to 800 Mhz (that with DDR, i guess, it's an effective 1600 MHz)
This is what i get in Antutu, but i had to clock the cpu to 1,2 Ghz min/1,8 Ghz max because at 1,92 was unstable...
Anyway, i can give you the modded kernel, or the rkpatchomatic source file i've changed.
I'm testing it now, with the largest 1080p movie i got, attached to the TV's usb, from a 3TB HDD... and so far it is going really nice!
Bye guys!Overclocked Kernels for Neomode's roms -> [KERNEL][AP6210] Overclocked kernels for Neomode ROMs (2.1/2.0/1.9a/1.7)
Originally posted by FrankieDedo View PostOk, after A LOT of tribulation, i had found a configuration that (probably) have stopped every major problem in video playback.
This is my config:
Bye guys!
Originally posted by babnik80 View PostWhat kernel did you have? What is NCR?Overclocked Kernels for Neomode's roms -> [KERNEL][AP6210] Overclocked kernels for Neomode ROMs (2.1/2.0/1.9a/1.7)
Originally posted by mymkv View Postso anyone was able to find good working combination of rom and kernel without fleakaring and working bluetooth with wifi?
I've noticed that the flickering was probably caused by an insufficient power source... i'm buying a 3A PSU then, just to be sureOverclocked Kernels for Neomode's roms -> [KERNEL][AP6210] Overclocked kernels for Neomode ROMs (2.1/2.0/1.9a/1.7)
Re: Neomode Custom Rom MK802IV / MK809III 2.1 BETA RK3188-T and RK3188
Originally posted by FrankieDedo View PostI've watched a whole Full HD movie without any blinking or choppiness, and wifi is good (but i have the antenna out of the case) i didn't tried bluetooth yet, but i think it should go well. I'll test some more and i'll post everything i find
There are currently 1503 users online. 0 members and 1503 guests.
