Neomode Custom Rom MK802IV / MK809III 2.1 BETA RK3188-T and RK3188
Originally posted by TVDroid View PostYou got this green Dots Image Error with stock ROM too ? Looks like your GPU is not the Best...HK1 Pro Plus
FlowFon F1
H96 Pro+ (Wisdom-Green Board-2017-02-10 H96-S912-TVBOX(DDR4)-V0.2)
MXQ Pro+
R-TVBOX Mini+
MK809III
It looks like as your GPU is damaged.
I see the same many Times, on damaged PC graphics Cards.
If you can return the Stick to the Seller, still better first not tinker with ventilators or something similar. Otherwise i would almost say you have a nice paperweight
But i dont want to make you fear and with this assessment i dont want to lean too far out of the window, but it looks realy like a damaged GPU.
I wish you luck Dude... TVDroid
> > > Devices: Minix Neo X7 & HiSilikon® T-R42 II < < <
Is there a software to take an image of each device so I can switch them around without having to reinstall apps and settings, etc?HK1 Pro Plus
FlowFon F1
MXQ Pro+
R-TVBOX Mini+
MK809III
HK1 Pro Plus
FlowFon F1
MXQ Pro+
R-TVBOX Mini+
MK809III
Originally posted by neomode View PostWell Sir, i would say your Wifi Module is either broken or it use a different
GPIO Point.
I think it is a different GPIO Point.
Neomode
I can get it working using the BT919 firmware, picture is fine and wifi works, just want to use your 2.0 firmware pal
how can i sort the GPIO point out, as that is what it sound like.
thanks for the help
Originally posted by potard View PostYes but don't stop blinking. Screen goes on and off every 2 secondes with Neo 1.7 and Sam kernel for me
For me the the screen now doesen't go on and off every 2 sec; but for every overclocked kernel I have an image distorting problem (lesser in 1080p and overclocking the gpu)...
GPIO Point.
Neomode
Got to try get this work mate, i have just installed v.2.0 on it again, and the picture is stable no lines or flashing, but cannot switch wifi on.
I also extracted the kernel from the BT919 firmware image, and replaced that in yours, and still no wifi, but the BT919 firmware does work with wifi, but i would like to have the 2.0
Sorry if this is in the wrong section
Just hope you can help
Is there anything i could try on this
please help
MK902 should work right?
Hey guys I just got my new box in and it sucks! It's the mk902 with rk3188 chipset. The riko site says it's based on the same technology as the mk802iv. Should the 802 roms work on my 902? I how so because this thing reboots if I look at it wrong. While it is on its super snappy and looks good.
OK what method is used to flash the rom? Hoping you say
Custom recovery flashing the file. On the 902 you have to go USB male to USB male cable to run the rk flash program
Originally posted by neomode View PostIt should Work. Because I tested my rom on a MK802IV with RK3188T.
Please try it ;-)
Neomode
There are currently 2521 users online. 0 members and 2521 guests.
